Autopilot install with a switch - Page 2 - SailNet Community
 6Likes
post #11 of 23 Old 02-17-2014
Re: Autopilot install with a switch
Originally Posted by Bob142 View Post
Sounds like your switch is giving you a dead short...check it with a meter if you have one...even new ones can be faulty...
Correct me if I'm wrong, but isn't that the purpose of a SPST switch?
Boredop is offline
post #12 of 23 Old 02-17-2014
mitiempo's Avatar
To give a dead short? No.
A SPST switch is designed to connect the incoming wire with the outgoing wire. Both wires are POSITIVE.
The op connected a positive to a negative and that is a dead short. No different than tossing a crescent wrench across the battery posts, he just used small gauge wire that burns faster!
Brian
mitiempo is offline
post #13 of 23 Old 02-17-2014 Thread Starter
Sailed it!
Hey Bore, thanks for using your very FIRST post replying with a non answer. Too bad we are not neighbors. You could watch me everyday. Keep up the clever conversation.
Thanks to everyone with helpful comments.
tcase10 is offline
post #14 of 23 Old 02-17-2014
BarryL's Avatar
Learning about electronics
Hey,
It occurred to me that my original response could have been more helpful. In case someone wants to learn more about basic electronics, there are number of TOYS that can help.
My dad was always buying things like this for my son:
50-in-1 Project Lab (eleep-50) Elenco Electronic Science Kits Non Solder
We would play around with them and you really can learn a lot about basic electronics.
Of course, there is a lot more information in books, but this is a cheap way to learn about wiring, switches, diodes, LED's, etc.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #15 of 23 Old 02-17-2014
azguy's Avatar
It was a mistake and you're still alive, if the auto polite is still ok, no harm, no foul and you learned something...
I'm glad people bring these issues to the forums, it helps me learn...
1988 C22 Owner
azguy is offline
post #16 of 23 Old 02-17-2014
mitiempo's Avatar
Time to get Charlie Wings book, Boatowners Illustrated Electrical Handbook - Second Edition
I'll second Maine Sail's recommendation. The best book I have seen on the subject, easy to understand and up to date.
http://www.amazon.com/Boatowners-Illustrated-Electrical-Handbook-Charlie/dp/0071446443/ref=sr_1_6?s=books&ie=UTF8&qid=1392693520&sr=1-6&keywords=charlie+wing
Brian
mitiempo is offline
post #17 of 23 Old 02-17-2014
Of course. Thats exactly what it is. So which side is which? Im having trouble figuring out what one is the outgoing..... Is it labeled?
And yes, my post was rather non answer, but if you cannot figure out a switch, maybe it is something better left to the professionals.
There are plenty of other projects you can do that leave the rest of the people moored near your boats in less jeopardy when you do it horribly wrong.
What kind of draw is your autohelm using, is your wire sized accordingly? Where is the overcurrent device? These are factors to be concerned about when doing electrical work, having both sides of the battery hooked up to either side of your switch suggests that you haven't thought about these other concerns.
Boredop is offline
post #18 of 23 Old 02-18-2014
mitiempo's Avatar
On a SPST switch it doesn't matter. You are connecting one side with the other.
This is a SPST
This switch is a SPDT and the center is the input.
Charlie's book could turn out to be a best seller.
Brian
mitiempo is offline
post #19 of 23 Old 02-18-2014
This is a SPST
Forgot the sarcastic font again. Sigh.
Dead short was the wrong term as it referred to a circuit, I rescind that statement.
What I was so awkwardly trying to get at was that it is just a basic switch, there are no options, off no continuity, on continuity. It just closes a gap, there are only two ways it can fail, open or closed. If you put that between the poles of a battery, and have to ask a community forum what is wrong, maybe electrical just isn't for you.
With another user suggesting they test this switch as it could be broken from factory, when the OP has :
A: Proof it works (almost melted ring terminal to battery)
B: Clearly no clue what he is doing.
This only furthers to confuse the problem, people who don't know how to troubleshoot telling people that have no knowledge or concept what to do.
It isn't that difficult, but the consequences for failure can be dire.
If you had absolutely no clue how to put in a thru hull would you just come and drill a hole in your boat?
How many fires on board are attributed to shoddy electrical?
Not only are you risking your personal health and safety, but you risking damage to other peoples property as well as their health and well being. Is that really worth not learning how to do it right? Or pay someone to do it?
When your boat burns down and writes off mine next to it and all I receive for that is actual cash value for my 5ksb? Thanks, I really appreciate it. Didn't work hard for that at all.
Boredop is offline
post #20 of 23 Old 02-19-2014
My suggestion to test the switch was so that in doing so he would find out what he was doing wrong on his own ...saying someone is stupid really doesn't help...
-OvO- likes this.
Bob142
Desolation Sound
Maple Leaf 48
Any storm in a port...
Bob142 is offline
Tags
auto pilot , catalina 27
How to install autopilot to a rack-and-pinion steering without pedestal-mounted whee Sadao Gear & Maintenance 14 04-04-2012 09:34 PM
Hydraulic Autopilot Install Question funjohnson Gear & Maintenance 6 11-06-2011 06:53 PM
Yard for Autopilot Install PalmettoSailor Chesapeake Bay 12 10-24-2011 08:37 PM
Pump Float and Three-Way Switch Install max-on Gear & Maintenance 38 05-27-2008 03:45 PM
C400 Batt install and Inv/CHg install Cruisingdad Catalina 1 08-01-2007 01:02 PM
