new bottom cleaning kit - Page 4 - SailNet Community
 9Likes
post #31 of 39 Old 02-27-2014
I don't discuss my member
Fstbttms's Avatar
Re: new bottom cleaning kit
As you are discovering, much of what is typically worn in the water by recreational divers simply becomes an encumbrance when cleaning boat bottoms. Leave as much of it ashore as possible. In a 14mm wetsuit, I suspect you are going to have to load up on lead to become neutral in the water, as well. Remember that you are maximumly bouyant near the surface. You need lots more weight for this kind of diving than you would use as a recreational diver.
Also, I recommend wearing a hood whenever doing bottom cleaning. The stuff you are knocking off the hull is not stuff you want in your ears.
Fstbttms is offline
post #32 of 39 Old 02-27-2014 Thread Starter
Schooner Captain
UnionPacific's Avatar
I was a bit curious where i might learn WHAT i am cleaning off the bottoms?
Some of it looked like little jelly fish, others looked like coral.....
UnionPacific is offline
post #33 of 39 Old 02-27-2014
Fstbttms's Avatar
I don't know what you know about anti fouling paints, but here is an informative primer on the subject that I make all my divers read:
http://www.yachtpaint.com/Literature...01_usa_eng.pdf
Fstbttms is offline
post #34 of 39 Old 02-27-2014
Fstbttms's Avatar
I'm sure that it was none of the above. Tunicates, sea squirts, algeas, South China Sea Coral Worm and various mollusks are typical fouling organisms found here in California. YMMV.
Fstbttms is offline
post #35 of 39 Old 03-01-2014 Thread Starter
Schooner Captain
I survived my 3rd yacht. Cleaned an identical boat to the bumfuzzles.
Now i know why cleaners wear hoods. I encountered a new critter.
Some sort of boat bottom dwelling shrimp.
I was literately attacked by them. I was covered by 1000's of these little critters, over every inch of the wetsuit, inside my wetsuit, and all over uncovered parts of my body.
They did do a good job of eating off all my scabs. It was interesting to see them all clung to the wound. I had an 8" gash on my leg that is now missing a scab.
Beyond that I had to deal with a very bad current, a ton of chop and shoddy work by the last bottom cleaner. (i found a huge 4" tall cluster of barnacles by the prop) It took me two hours to clean it. Not sure if that is good or not.
It was a great workout.
FSTBTTMS where did you buy those 3M pads and holder? i checked home depot to no avail.
post #36 of 39 Old 03-01-2014 Thread Starter
Schooner Captain
Read, but i do not see that type of growth here for some strange reason, seeing new and odd creatures. Some of those i did see.
post #37 of 39 Old 03-01-2014
Fstbttms's Avatar
I was literately attacked by them. I was covered by 1000's of these little critters, over every inch of the wetsuit...
Welcome to the club.
I had to deal with... shoddy work by the last bottom cleaner.
No offense, but you've cleaned three boats in your entire life. You don't have the experience to know how fast fouling growth can accumulate on a boat bottom, especially in a high fouling region, especially on a boat that maybe hasn't been given the TLC she needs by her owner. I think if you were to dive that same boat again in a few weeks, you'd be very surprised at what you found. Don't assume that the last guy under that boat did a lousy job.
...where did you buy those 3M pads and holder? i checked home depot to no avail.
The 3M Doodlebug pads are available at any janitorial supply house, but I get mine from my local chandlery. The holders I make myself.
Fstbttms is offline
post #38 of 39 Old 03-01-2014 Thread Starter
Schooner Captain
water temp is 52 degrees, was last cleaned 3 weeks ago. how long at that temp does it take a cluster to grow 4" tall, 3" round?
will check the janitor supply house. will have to make my own holder too i guess Although i will stick to coco, not alcohol.
post #39 of 39 Old 03-01-2014
Fstbttms's Avatar
You'd be surprised how fast barnacles can grow. Water temperature is just one of many factors affecting fouling rates. It may very well be that the last diver didn't do a good job. But you didn't see the bottom just after it was cleaned so, who knows? The point is, you are making an assumption about another man's livelihood and reputation. An assumption that could be wrong.
nighthawk likes this.
Fstbttms is offline
bottom cleaning SFWindChaser Gear & Maintenance 10 11-27-2009 10:41 AM
More on bottom cleaning Ajax_MD Gear & Maintenance 3 11-26-2009 05:22 PM
Bottom Cleaning nereussailor Gear & Maintenance 14 11-19-2009 11:17 AM
Annapolis Bottom Cleaning SteveInMD Gear & Maintenance 3 07-21-2008 01:35 AM
Bottom cleaning mwrohde Gear & Maintenance 4 07-13-2008 10:52 AM
