new bottom cleaning kit - SailNet Community
 9Likes
post #1 of 39 Old 02-17-2014 Thread Starter
Schooner Captain
UnionPacific's Avatar
I need to assemble a common group of tools i will need for my new bottom cleaning business. This is my list so far, any recommendations would be great.
scotchbrite pads
2" scraper
6" flexible scraper
2"x2"x2' piece of wood
Allen key set
flat and straight screwdriver
rubber mallet
brass hammer
anything i have missed?
UnionPacific is offline
post #2 of 39 Old 02-17-2014
Re: new bottom cleaning kit
Underwater cleaning?
Seaduction is offline
post #3 of 39 Old 02-17-2014
Sailor
Gladrags1's Avatar
We need some more detail about your proposed business. The scope of your venture. Are you planning on cleaning the boat when out of the water or in? Most marinas powerwash the bottom when the boat is hauled so that would cut into your business. Are you looking to clean big yachts or day sailors (who wouldn't get power washed necessarily). If cleaning on land, you might want a portable power washer yourself. If you are cleaning in the water, snorkel gear at the least.
I am assuming the Allen wrench set is to change zincs, correct? Then a ball peen hammer is helpful to give the zincs a whack to set them.
You might want a long handled scraper to remove barnacles.
Probably more items will come to mind. Oh, here's one: a plastic drop cloth to catch the stuff as many areas are starting to regulate what happens to the runoff from bottom cleaning. You should check on regs in your area too.
Good luck!
Tod
Mandolin, Bayfield 36 out of Rock Creek, Chesapeake Bay.
Sent from my iPhone using Tapatalk
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #4 of 39 Old 02-17-2014
Diving? A suction device to hold yourself in place is useful. Scotchbrite can be harsh, especially on ablatives. You want the softest scrub medium possible for the growth. Lanyards on everything.
Jeanneau 54DS
Minnewaska is offline
post #5 of 39 Old 02-17-2014
scotchbrite pads
2" scraper
6" flexible scraper
Allen key set
rubber mallet
brass hammer
The fact that you're about to go steaming in with scotchbrite pads is scary. Try reading this :
http://www.coastal.ca.gov/nps/in-wat...-3-14-2012.pdf
You're supposed to be cleaning most paints with soft carpet.
MarkSF is offline
post #6 of 39 Old 02-17-2014 Thread Starter
Schooner Captain
Sorry, this will be underwater. Basing the scotchbrites on what I have seen used to clean bottoms by pros who do them now. they come in many grits, from soft to ultra heavy duty.
suction device sounds great!!! thank you.
post #7 of 39 Old 02-17-2014
Old enough to know better
You will likely want a hooka or scuba tanks. But hooka is likely easier. You w ill want to make sure you are up to date on the regulations in your area. Yet are more likely to come after a new operator.
Sent from my ADR6425LVW using Tapatalk
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #8 of 39 Old 02-17-2014 Thread Starter
Schooner Captain
Going with tanks. Hooka is far too costly. I will plan to buy at least 4 tanks. Eventually we will get a dive compressor for our own use.
post #9 of 39 Old 02-17-2014
I would suggest that four tanks, each requiring VIP and hydro certifications, and having them filled someplace, and commuting to get the fills, and the inevitable "Oh, your tank isn't ready, can you come back Tuesday?" are going to cost way more than a hookah will. And a small dive compressor chews through consumables, like filters, making it more expensive than shop fills. Just make sure you have considered everything when you run your numbers, especially those "consumables" and extra trips because the tanks weren't filled.
Cheapest source for ScotchBrite used to be from janitorial supply houses. They sell it for floor scrubbing machines in large discs (wheels) that are way cheaper than the small pads you buy elsewhere. But using ScotchBrite for bottom cleaning is getting slammed everywhere, even in Practical Sailor this month.
mitiempo and jimgo like this.
hellosailor is offline
post #10 of 39 Old 02-17-2014 Thread Starter
Schooner Captain
I am finding AL80's for $35 each, plus hydros and vip and fill for $30. after that my dive shop fills them the same day. $5 each. We will not use the compressor until we are far from America.
bottom cleaning SFWindChaser Gear & Maintenance 10 11-27-2009 10:41 AM
More on bottom cleaning Ajax_MD Gear & Maintenance 3 11-26-2009 05:22 PM
Bottom Cleaning nereussailor Gear & Maintenance 14 11-19-2009 11:17 AM
Annapolis Bottom Cleaning SteveInMD Gear & Maintenance 3 07-21-2008 01:35 AM
Bottom cleaning mwrohde Gear & Maintenance 4 07-13-2008 10:52 AM
