Seaview radar mast mount - SailNet Community
post #1 of 4 Old 01-23-2006 Thread Starter
Would welcome any experience or suggestions for installation of the mast mount platform for a radar dome. This would include balancing, getting the thing level without dropping too many things. Thanks in advance!
Neicy is offline
post #2 of 4 Old 01-26-2006
Neicy,
I''ve installed a Furuno radar on my mizzen mast but the same would apply to any mast, I guess.
I used a spare halyard to hold the mount at the location I wanted and a couple of bar clamps to hold it tight to the mast. Using a level I got it clamped into the position I wanted then marked the holes in the mast for the fasteners. I used 1/4-20 SS machine screws (three per side) with holes drilled and tapped. To prevent electrolytic corrosion I used Tef-Gel (Ultra Safety Systems) on the screws since the mast and mount are aluminum.
When you consider the movement of the mast while underway you don''t have to be too concerned about getting it ''exactly'' level. And I think you will find there is an adjustment inside the radome for any athwartship alignment that is needed.
Terry
admin is offline
post #3 of 4 Old 01-27-2006 Thread Starter
Terry,
Thanks for the sugguestions. My Mounting bracket came with rivets to attach it the mast. I plan to purchase a rivet gun or borrow one, but will use Tef-Gel to prevent the corrosion. Again thanks!
Neicy
Neicy is offline
post #4 of 4 Old 02-13-2006
Just use aluminum pop rivets, then you have no corosion worries.
redcorvette1995 is offline
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
