Magma Grill Question - SailNet Community
post #1 of 6 Old 01-23-2006 Thread Starter
I have the Newport model and wish to connect it to the 20lb. house propane tank.
I have the A10-225 hose kit and the A10-220 Valve, but can''t figure out how it is supposed to hook directly to the grill.
Anyone?
PhotoEd is offline
post #2 of 6 Old 01-23-2006
Señor Member
TrueBlue's Avatar
I have the standard Magma grill and connect directly to my 10lb bottle w/o problem, using an extension hose kit & valve. Not familiar with the Newport valve connection, but perhaps this diagram from Magma will help . . . (cut & paste the entire url)
http://magmaproducts.com/Products/Marine_Products/Gas_Barbeque_2/Gas_005/Page10281/Gas005_Control_/A10-220_details_web.PDF
Newport owner''s manual . . .
http://www.magmaproducts.com/A10-918_manual.pdf
TrueBlue is offline
post #3 of 6 Old 01-25-2006
After the bottle there must be a regualtor or the pressure will be too high for the grill. A selonoid is also required for safe operation. Mine is before the regualor as my stoove uses it too. The stove does not require a regulator.
I have a shut off for the line that goes to the grill located after the regulator so I can disconnect the hose to the grill but leave it attached to the valve on the grill. It hand tightens fine.
I set up the grill then attach the hose to the 10-220 valve. You can get the hose and fittings at any propane dealer. It''s not a special marine hose. Some times a few more feet helps to locate it where you want.
PaulBl is offline
post #4 of 6 Old 01-26-2006 Thread Starter
The issue I''m having is where the A10-220 valve attaches to the Newport itself. The actual mating of the two pieces...
The original regulator that you would screw a 1lb. bottle into has a notch that you must align while sliding it into the base of the grill...the A10-220 does not have that notch.
Anyone using the Newport with house propane?
PhotoEd is offline
post #5 of 6 Old 01-26-2006
Señor Member
TrueBlue's Avatar
PhotoEd,
According to the Magma Valve Application Guide, it seems that you will need the A10-220, Type-3 valve for the Newport grill. The A10-220 is noted as being the old type.
http://www.magmaproducts.com/Index/Valve_Application_Guide.pdf
The Newport manual link, also makes note of this with an assembly diagram on page 6, showing the notched "lock detent".
Steve
TrueBlue is offline
post #6 of 6 Old 02-03-2006 Thread Starter
Thanks to everyone for their time!
What I found out is that I have an outdated A10-220, and that the NEW A10-220(Type3) has the connector I need...and it''s on the way!
Anyone need the old style? It''s bronze in color and doesn''t have the detent.
PhotoEd is offline
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
GPS question wallm General Discussion (sailing related) 13 05-30-2004 02:10 AM
Singlehand question on buying new boat eddieb Boat Review and Purchase Forum 5 04-06-2004 10:21 PM
Rudder anode question aflanigan Gear & Maintenance 2 01-03-2004 12:25 PM
question on sails Mark_OD23 General Discussion (sailing related) 6 11-19-2002 04:41 PM
