Butyl tape good or bad - SailNet Community
post #1 of 22 Old 02-20-2014 Thread Starter
OUPV 25 Ton
CaptainRahnn's Avatar
I've read mainsails suggestion about bedding hardware with butyl tape. I've been getting mixed reviews at my local boat yard and club. Anyone actually used this stuff for bedding hardware.
Thanks
1976 Cal 34 mk2
"Shameless"
CaptainRahnn is offline
post #2 of 22 Old 02-20-2014
Ticon 30
dbruce85's Avatar
Re: Butyl tape good or bad
I have used it, it is great. Make sure you get a good quality tape, it is not all the same.
Canadian Sailcraft used butyl to bed hardware, after 15/20yrs, they were still not leaking.
Read the 'Sticky" on rebedding hardware with Butyl by Mainsail, one of the 1st posts in the Gear and Maintenance section
dbruce85 is offline
post #3 of 22 Old 02-20-2014
ericb760's Avatar
If you watch Don Casey's older videos on youtube regarding bedding hardware, he has put disclaimers on all of them regarding the use of silicone, stating that his preferred and suggested method today is to use butyl tape. If it's good enough for Don Casey, it's plenty good enough for me.
ericb760 is offline
post #4 of 22 Old 02-20-2014
69' Coronado 25
socal c25's Avatar
Dock
I am adding deck hardware to my Coronado 25 with butyl and it is working out well, I will ber rebedding all the rest of the hardware and stanchions etc... with butyl. There is a butyl putty that you want to stay away from and make sure you get a tape that is of good quality, do your research and then go to work...
"There are those that stand at the shore looking to the sea, wondering, and there are those standing at the helm looking back at shore, knowing." - Kurt Leisenfelder
"Fiberglass shells that let us breathe, let us smell, keep us from going numb"- Kurt Leisenfelder
My Avatar is a pic of my son - Jan 19, 2014.
socal c25 is offline
post #5 of 22 Old 02-20-2014
jsaronson's Avatar
MaineSail sells top grade stuff. My 30 year old boat has it In the deck joint and it is still pliable and watertight.
jsaronson is offline
post #6 of 22 Old 02-20-2014
I have rebedded deck hardware, port lights and the winch bolts on a venture 22 with butyl tape from Mainesail. After 3 years, no leaks on anything. Plenty good enough performance for me to buy 2 more rolls for my new to me Tartan 34c.
tsell is offline
post #7 of 22 Old 02-20-2014
Tartan 27' owner
CalebD's Avatar
Suggest you try working with 3M 420 or similar compound and then try working with Butyl tape.
You will never look back.
Everybody has one:
CalebD is offline
post #8 of 22 Old 02-20-2014
Originally Posted by jsaronson View Post
..... My 30 year old boat has it In the deck joint and it is still pliable and watertight.
As is ours, same age...
Order it from Maine Sail, follow his tips, and I think you'll be golden.
Faster is online now
post #9 of 22 Old 02-20-2014
pdqaltair's Avatar
I had to replace a butyl-bedded hatch. After 15 years, still pliable.
The right answer for many things.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #10 of 22 Old 02-21-2014 Thread Starter
OUPV 25 Ton
I bought some at an RV store. It's very easy to work with compared to caulking/adhesive and faster to clean up. I bed my jib track today and I actually liked working with it. Reminds me of silly putty. I had several leaks that appear to be gone. Awesome stuff.
1976 Cal 34 mk2
"Shameless"
Tags
bedding , butyl tape , hardware , sikaflex
Where to get Butyl tape? Paladin27 Gear & Maintenance 31 02-23-2014 03:25 PM
Butyl Tape Source...The Good Stuff rhr1956 Gear & Maintenance 23 08-12-2013 03:05 PM
butyl tape MarkusM Gear & Maintenance 10 06-14-2012 10:34 PM
Good deal on butyl (self-vulcanizing) repair tape hellosailor Gear & Maintenance 11 10-13-2010 06:19 PM
butyl tape pegasus1457 Gear & Maintenance 53 04-30-2009 05:58 PM
