Making wooden spreaders. Material? - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree22Likes
Old 02-21-2014
L124C's Avatar
L124C is on a distinguished road
Getting ready to pull the stick on the Yankee 30 and know I need to replace at least one spreader. I have a nice piece of teak. Any reason I shouldn't use it to fabricate spreaders?
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 02-21-2014
deltaten's Avatar
deltaten is on a distinguished road
Send a message via Yahoo to deltaten
Re: Making wooden spreaders. Material?
weight?
StormBay likes this.
S/V Chrysalis
'80 Watkins 27
North East, MD
  #3
Old 02-22-2014
newhaul's Avatar
islander bahama 24
newhaul is on a distinguished road
There's really no reason not to make them out of good straight grain teak. However traditionally they would be out of good soft wood like spruce, ceder, or Douglas fir. The most important however is straight tight grained see what the original spreaders are made of and try to duplicate it
RichH and christian.hess like this.
Illegitimus Non Tatum Carborundum.
The Following User Says Thank You to newhaul For This Useful Post:
L124C (02-22-2014)
  #4
Old 02-22-2014
Alex W's Avatar
no longer reading SailNet
Alex W is on a distinguished road
You can get aluminum spreaders for the Yankee 30 rig from the original manufacturer. Check the Yankee 30 list, I think the mast was made be LeFiell in CA.
The Following User Says Thank You to Alex W For This Useful Post:
L124C (02-22-2014)
  #5
Old 02-22-2014
L124C's Avatar
Interesting, and counter intuitive to me. Why softer wood? I would think you would want to use a harder, more weather resistant wood.
  #6
Old 02-22-2014
L124C's Avatar
Thanks! Gotta love this site...learn things all the time.
Don't know what the "Yankee list" is, but emailed LeFiell with a inquiry.
LEFIELL MARINE PRODUCTS
If they make them, It will feel freaky to order a factory replacement part for the 40+ year old boat. Certainly a first for me, didn't even consider it!
Are Aluminium spreaders necessarily better than wood? As with most things, I'll bet there are pros and con's. One pro for wood is that I can make them. However, I'd be happy to buy aluminum if the price isn't prohibitive.
  #7
Old 02-22-2014
newhaul's Avatar
islander bahama 24
The soft woods are traditionally used due to lighter weight straight grain and more flexible for spars hard woods won't flex and are actually more likely to break under sailing loads than soft woods.
L124C (02-23-2014)
  #8
Old 02-22-2014
Old enough to know better
miatapaul is on a distinguished road
Yup, I think as teak ages, it would tend to split and crack under the stress of the rigging. Softer woods are lighter and will flex more and not crack or split. Since they are aloft they tend to dry fairly quickly so rot is not as much of an issue, like it would be on a toe rail. That said, they do tend to rot out near the fixtures that will hold the moisture against the wood.
Aluminum is a good option as it will likely last longer than the boat, but the original ones lasted this long and would be cheap and easy to make. It is harder to get good spruce than it once was, but if I had a good source that is the way I would go. Should last another 40 years or so. That is about as long as I expect to be sailing. Though who knows I might be climbing the mast to replace them when I am 90!
The Following User Says Thank You to miatapaul For This Useful Post:
L124C (02-23-2014)
  #9
Old 02-22-2014
Cap-Couillon's Avatar
Noah's Bosun
Cap-Couillon is on a distinguished road
If you decide to go with wood spreaders, given the limited availability of old-growth (tight grained) spruce, "pattern grade" South American mahogany is a good choice.
While not as light as spruce, it is very tight grained and in "pattern-grade" straight grained and essentially defect free. Exceptional dimensional stability, good workability and easy on the tooling. $6.00-$12.00 / bd-ft depending on your source. A chunk 5/4"x4"x96" is 3.3 bd-ft. Check in your local area for "custom mill-work" who will probably have what you need without having to deal with shipping and minimum orders.
Most shops will sell you a single piece to DIY.
Teak while very resistant to abrasion and rot (High silica and oil content) is IMHO over rated and over used in marine applications. Good decking material as used in old ships, but poor dimensional stability, hell on the tooling (high silica content) and tough to get an adequate glue joint (oil content).
benesailor likes this.
"If the wind will not serve, lay to the oars"
Onboard - Solitaire
The Following User Says Thank You to Cap-Couillon For This Useful Post:
L124C (02-23-2014)
  #10
Old 02-22-2014
christian.hess's Avatar
"Nubile Southern Sailor"
christian.hess is on a distinguished road
yeah teak no good here...think what old wood spars are made of mostly spruce or fir...
you want light and flexible....
a lot of give is involved in spreader design, even in aluminum or glass...
I have to fix my port upper spreader on my boat, slightly cracket ath the mount bolt at the mast..but since its glass its an easy epoxy putty seal and maybe a wrap of glass there and Im good to go
Islander 36 now FOR SALE!
The Following User Says Thank You to christian.hess For This Useful Post:
L124C (02-23-2014)
You may post attachments
You may edit your posts
repairing wooden spreaders with mast steps installed dan8152 Gear & Maintenance 13 03-16-2014 06:14 PM
Cal 2-27 Spreaders SteveMartin Gear & Maintenance 5 07-11-2009 10:43 PM
spreaders Leland Gear & Maintenance 22 05-20-2008 07:24 PM
Spreaders sailaway21 Gear & Maintenance 7 04-03-2007 08:26 PM
Looking for Spreaders RookieHunter Gear & Maintenance 5 11-23-2002 05:23 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
