Blogs
User Name
Old 02-05-2006
sailortjk1's Avatar
sailortjk1 sailortjk1 is online now
sailortjk1 will become famous soon enoughsailortjk1 will become famous soon enough
Varnish Removal Question
The previous owner of our boat used varnish on all the teak. The seats and cockpit floor boards. It was in bad shape in spots and was flaking and pealing. Most of the surface is sound.
My plan is to strip it down to the bare wood, clean it and than recoat it using something other than varnish; perhaps Creatol.
I am currently in the stripping process and I am using chemical strippers. I''m finding that I can get the top layers of old varnish off, but when I get down to the base, the wood still has the old yellowish glow of the old varnish. At this point I tried sanding, but I still have the yellow glow.
My questiom is; will I ever get down to the natural wood or will I always have that last bit of color in the wood?
Old 02-06-2006
WHOOSH WHOOSH is offline
WHOOSH is on a distinguished road
Wood''s surface is uneven and that''s one reason you''ll ultimately need to sand. However, I would recommend you buy a high-quality scraper or two (not those Red Devil things) and a 1000/2000 watt heat gun. Using the low setting, melt/strip the varnish. Be careful of the gelcoat. This is IMO far easier, also quicker, and produces the best results you can hope for before sanding in less time. I suffered thru the same experience you are now when we bought our 42'' ketch. Ever since, I''ve found the heat gun the best way to remove the various teak coatings I''ve used.
Good luck; it''s a labor of love.
Jack
Old 02-06-2006
gstraub gstraub is offline
gstraub is on a distinguished road
I second Jack''s opinion. I have used a heat gun with great success. You just have to be a bit careful where you aim it and how long you keep it there!
Gerhard
Old 02-06-2006
TrueBlue's Avatar
TrueBlue TrueBlue is offline
Seņor Member
TrueBlue is a jewel in the roughTrueBlue is a jewel in the roughTrueBlue is a jewel in the rough
sailortjk1,
I will also second Jack''s recommendation for using a heat gun and quality scraper over using chemical strippers. It is definitely the best method and how the pros do it.
My Nauticat has a forest of teak, inside and out. After purchasing the boat in ''04, I knew the exterior teak needed to be stripped down to bare wood & recoated. It was a job I initially thought I would do, but after extensive research, decided to hire a professional crew instead. It was the best decision made.
I watched as they skillfully melted many layers of varnish with heat guns and razor-sharp scrapers. The layers curled off in ribbons, down to bare teak, with very little effort. Tough to get at areas required some chemical stripper and a final light sanding using 80-100 grit papers smoothed the surface with enough tooth for the sealer coat. The resulting 18 year old wood looked brand new when they finally finished.
Since I have a very profitable business to run, my rationalization of earning billable hours while they did all the grunt work was a no-brainer. I did the easy and glorifying job of applying the new finish coats and in the process, could detect no discoloration at all, just a natural, light brown teak color.
Steve
Old 02-06-2006
sailortjk1's Avatar
Thanks to everyone for their responses. Sounds like a heat gun will be added to the tool box.
Display Modes
vB code is On
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
Interlux Perfection Varnish (2 part) mikehoyt Gear & Maintenance 0 05-31-2004 05:50 AM
GPS question wallm General Discussion (sailing related) 13 05-30-2004 02:10 AM
varnish removal joseph53p Gear & Maintenance 3 11-29-2003 07:12 AM
Varnish remains off Deck jb Gear & Maintenance 3 04-28-2002 08:38 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
