Installing dodger questions - Page 2 - SailNet Community
 6Likes
post #11 of 23 Old 02-23-2014
Maine Sail's Avatar
Re: Installing dodger questions
Originally Posted by rbyham View Post
Oops... Here's the needed pic...
A good canvas guy can re-cut that for short money and do a nice install. You already need new glass so just have them do the whole thing..
christian.hess likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #12 of 23 Old 02-23-2014
christian.hess's Avatar
x2...take a pic send to a canvas or even better a car upholestery shop, why better cause they are much cheaper
I had some work done up in california by a VERY skilled mexican upholester, he did stuff for my boat as well as an old honda cb750...redid seats, foam etc...
try to avoid sail lofts as they will be much more expensive
do yourself a favor and buy scrap sumbrella or dodger canvas as well as some uv resistant thread(nylon)
then with dodger, thread, and scraps say you need this trimmed here and there, reinforced here, made to this shape...show pic
thats all most good canvas or upholester workers need
they have great eyes for detail
I just had my dodger fixed and stitched and reinforced down here
$25 bucks and I have a nice sealed and refitted dodger
cheers
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #13 of 23 Old 02-23-2014
Group9's Avatar
The dodger has several sewn in female parts of the twist connectors. Not sure what those are called. Maybe a combination of the twist connectors and snaps would yield an acceptable and sufficiently strong result.
That's what holds most of my dodger own, with some snaps, too. I don't think velcro would cut it without something else anchoring the main attachment points.
I think I would get the mail side of the oval twist lock connecters and put them in. Those can get in the way when the dodger is off, though. And, I leave mine off in the summer.
On the northern Gulf of Mexico.
"Best thing to do is get her out on the ocean. If anything's gonna happen, it's gonna happen out there." Captain Ron Rico
Group9 is offline
post #14 of 23 Old 02-23-2014
Markwesti's Avatar
For the leading edge that attaches to the cabin top mine has a piece of teak screwed to the cabin top . The leading edge of the teak is angled back to match the angle of the leading edge of the dodger , lift dot pegs are screwed in the teak . Lift dot females are in the dodger .
Markwesti is offline
post #15 of 23 Old 02-23-2014
Master Mariner
capta's Avatar
I would highly recommend against snaps, unless you are sailing in fresh water. They corrode up pretty quickly and become unusable, often tearing out with the pressure necessary to open them. There are Twist Studs that are stronger, never corrode and they cannot open accidentally. The only drawback is you must have the female pieces installed by a canvas person, unless you want to buy a $300.00 tool.
facebook.com/svskippingstone
Our Videos;
capta is online now
post #16 of 23 Old 02-23-2014 Thread Starter
rbyham's Avatar
Thanks all. This confirms velcro as a bad idea. If you look close each key corner has the female/receiver part of a common sense connector so I think I could get away at least for temporary with installing some studs where needed. To show how cheap I can be, i took the dodger home, let it warm up indoors and then with a hairdryer got the strategiesStrataglass supple again. I then cleaned the torn sections carefully and with more heat pulled the tears together nicely and applied clear vinyl tape. Again a temp fix but one that causes the dodger to better hold its shape. This will allow me to go for a tight fit on the boat using the common sense connectors. After that I will get better pics and work with canvas guy during hot summer months. Hope to update with pics unless it looks too ugly. :-)
rbyham is offline
post #17 of 23 Old 02-24-2014
FSMike's Avatar
This works very well and also helps keep water from running under the dodger in bad weather.
No matter what type of fastener you use monthly lubrication (I use Vaseline) will help the longevity.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
The Following User Says Thank You to FSMike For This Useful Post:
Markwesti (02-24-2014)
post #18 of 23 Old 02-24-2014
You can also hit your fasteners with a shot of silicone to keep corrosion down.
Do, though, be picky about what you clean the Strataglass with. Don't use windex or the like. General cleaning with soap and water. You can buy specific cleaner for Strataglass, IMAR is pretty good stuff. You use it quite sparingly, it'll last a long time
The Care and Feeding of Strataglass
Multihullgirl is offline
post #19 of 23 Old 02-24-2014
Sailing Junkie
ehmanta's Avatar
It looks like if you moved the stainless frame back a few inches, the curved bottom of the dodger would miss that fixed portlight. I don't know how much you can move it back before it no longer covers the seahood though.
Don't use silicon spray without protecting for overspray (you don't want it on the deck)
"Dragonfly"
Tartan 4100, #28
ehmanta is offline
post #20 of 23 Old 02-24-2014 Thread Starter
rbyham's Avatar
Thanks all. I went with the common sense connectors. Came out pretty good. Will probably have a pro fit it to boat when it gets warmer around here.
Group9 likes this.
rbyham is offline
New Dodger Thistle Dew Gear & Maintenance 27 10-10-2013 01:25 PM
Anyone tried dodger? prroots Beneteau 3 02-14-2013 12:17 PM
Questions RE: Installing Interior 12v LED Light Strips Doc_V Gear & Maintenance 14 10-05-2012 11:51 PM
questions about installing portholes Fitz87 Gear & Maintenance 6 09-27-2010 12:23 PM
hard dodger vs soft dodger bluetommy77 Boat Review and Purchase Forum 6 10-07-2007 06:29 PM
