Installing dodger questions - Page 3 - SailNet Community
 6Likes
post #21 of 23 Old 02-25-2014
Re: Installing dodger questions
That looks quite a bit better than I would think a repurposed dodger from a different boat ever could. However, I would remain concerned that the flap over your side window is going to flog and do some damage. Good luck.
Jeanneau 54DS
Minnewaska is offline
post #22 of 23 Old 03-04-2014 Thread Starter
rbyham's Avatar
Yes it came out well leaving me now with a different question. My profile pic shows the original bimini still in place. It is now gone but would appear to be a candidate to shade the rest of the cockpit if hung right. It fits length and width wise real well. The challenge is height. Using the coaming just forward of the primary winches would seem most natural. However how do I get the needed 6" height increase needed to give me clear vision forward over top of dodger.
rbyham is offline
post #23 of 23 Old 03-05-2014
Asleep at the wheel
jimgo's Avatar
One idea would be to take/cut the bottom bracket off the existing frame and make extensions. The extension I'm envisioning would have 2 pieces. The first piece is the main, "outer" piece and is your desired 6" long piece and it matches the outer and inner diameters of the existing frame. If it was mounted using set-screws, the original bracket can be reused and put at the bottom of this first piece. The second piece of the extension is an inner tube whose outer diameter is the same as (actually just a HAIR smaller than) the inner diameter of your existing frame's tube. This one would be cut to be about 12" long. The inner tube slides inside the main, outer extension tube and also into the existing frame. Set-screws, pins, or bolts are used to attach the inner piece/tube to both the existing frame and the outer piece of the extension.
Another idea would be to use something like this:
Stainless Steel Rail Fitting Tees 90 deg 1-1/4"
Or this:
Stainless Steel Connection 1"
I'm not sure how well something as short as those would work if someone pulls on/leans on/falls against the bimini, though. I think I'd prefer to have some of the force distributed along a bigger portion of the frame, that's why I suggested the set-up above. Of course, never having actually done any of these options, I could be WAY off base, but...
And, of course, the most obvious way to get the desired 6" is to buy a new bimini that is taller than you need and "just" cut it down.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
New Dodger Thistle Dew Gear & Maintenance 27 10-10-2013 01:25 PM
Anyone tried dodger? prroots Beneteau 3 02-14-2013 12:17 PM
Questions RE: Installing Interior 12v LED Light Strips Doc_V Gear & Maintenance 14 10-05-2012 11:51 PM
questions about installing portholes Fitz87 Gear & Maintenance 6 09-27-2010 12:23 PM
hard dodger vs soft dodger bluetommy77 Boat Review and Purchase Forum 6 10-07-2007 06:29 PM
