Grooves in Keel? Baffled... - SailNet Community
 1Likes
  • 1 Post By bobperry
post #1 of 10 Old 02-24-2014 Thread Starter
Question Grooves in Keel? Baffled...
I had a survey on my new boat over the winter. It came up that there was a little pinhole which showed signs of weeping water. There was water in the bilge during the survey so he recommended removing all the water and sealing the keel bolts with a little bit of sealant. This past weekend I sealed the keel bolts, in in my desire to take everything apart I drilled a few holed around the pinhole (water came out). This led me to using a Dremel to remove even more material and I was amazed/extremely confused about what I found. Attached are 3 pictures 0742 is of the location on the keel, 0744 is of the grooves in the keel, and 0748 is of the piece of fiberglass removed.
I am totally confused. Why are there grooves in the fiberglass… Why is there fiberglass over the lead. My past boat was barrier coat over lead. The difference between my past boat (New York 36) and the current boat (Frers 41) is the aft edge of the keel is curved (the curved part is not lead). Are these slats put in to support the tail edge of the keel? Or are these grooves/slats put in for another purpose???
Either way has anyone had any issues with water in these grooves before. If so how did you drain them all, are they all connected in one point? Where would the water come from?
Schock - New York 36
Portsmouth, RI
mm2187 is offline
post #2 of 10 Old 02-24-2014
Lake Superior Sailor's Avatar
Re: Grooves in Keel? Baffled...
Looks like pre manufactured material used to cover lead keel...Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #3 of 10 Old 02-24-2014
Tim R.'s Avatar
What are they made of? It looks like foam.
I would assume that the designer wanted a specific keel profile that was larger than the acceptable keel based on weight so they had to build out from the lead.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #4 of 10 Old 02-24-2014
grumpy old man
I wopnder if the grp was not laid up as a "skin" then bonded to the lead. If that was the case maybe the grooves are to get more bonding area. Although I've never seen that before. It was not unusual to have a grp skin over lead as the grp was easier to fair.
Is this a Barry Carrol boat? If it is call Barry, tell him "Bob sent you". He's a nice guy.
Bob's Blog ....
bobperry is offline
post #5 of 10 Old 02-24-2014 Thread Starter
Bob, It is a Carrol Marine boat built in 1988, but they are no longer in business.
Portsmouth, RI
mm2187 is offline
post #6 of 10 Old 02-24-2014 Thread Starter
The material is some sort of hard resin or some sort. It is not light weight like foam.
Portsmouth, RI
mm2187 is offline
post #7 of 10 Old 02-24-2014
Looks like they used a grooved tiling-type trowel on the keel and used that to bond a pre-layed-up skin to the keel, which probably incorporated the rounded trailing edge, and faired that overall.
The thick glue strakes probably allowed them to preposition the skin to the desired foil shape before it all set up??
Interesting discovery, though!!
Faster is offline
post #8 of 10 Old 02-24-2014
grumpy old man
mm:
Yes, I know that. But if you could track Barry down he'd answer your question. Just mention my name. Blame me.
ottos likes this.
Bob's Blog ....
bobperry is offline
post #9 of 10 Old 02-26-2014 Thread Starter
mm:
Bob,
I ended up taking your advice and got in contact with him. I did mention your name and he knew exactly who you are! Sounds like they ened up putting a skin of fiberglass on the keel to allow for better fairing as well as paint adherance. Extreamly nice guy!
Portsmouth, RI
mm2187 is offline
post #10 of 10 Old 02-26-2014
Wouldn't all the voids behind the fiberglass cause serious issues/failures with water and freezing in the winter time? I guess it has worked so far.
benesailor is offline
Questions about barrier coat on steel keel, and sealing keel joint EricinToronto Gear & Maintenance 1 04-21-2012 09:43 PM
GPS / ChartPlotters; Totally Baffled hriehl1 Gear & Maintenance 33 12-29-2010 10:25 PM
Searchers Baffled By Disappearance Of SF Sailor (Bayinsider) NewsReader News Feeds 0 01-31-2007 05:15 AM
Searchers Baffled By Disappearance Of SF Sailor (KTVU 2 San Francisco) NewsReader News Feeds 0 01-30-2007 12:15 PM
Searchers Baffled By Disappearance Of SF Sailor - KTVU.com NewsReader News Feeds 0 01-30-2007 12:15 PM
