Remove Varnish from Teak Caulk - Page 2 - SailNet Community
 7Likes
post #11 of 29 Old 02-25-2014
Re: Remove Varnish from Teak Caulk
Scotchbrite is a good idea. Scrub the teak too.
GMFL likes this.
Jeanneau 54DS
Minnewaska is offline
post #12 of 29 Old 02-25-2014
Once known as Hartley18
Classic30's Avatar
Dock
Originally Posted by Minnewaska View Post
In any event, varnish isn't going to seal well to caulking, which means any cracking between the caulk and plank will allow water in and that's the death of varnish. Most things I see varnished, do not have caulk joints. Even without them, varnish is hard enough to maintain.
To be honest, for the application in GMFL's photos, he'd be far better advised to use a soft-setting absorbent Teak Oil of some kind - not a hard varnish - for all the reasons you mention.
If varnished he'd have to do it all over again in a year or two anyways.. and an oil is far easier to maintain if caulking is involved.
Classic30 is offline
post #13 of 29 Old 02-25-2014 Thread Starter
Large Member
GMFL's Avatar
Sorry, I have to totally disagree with you here. This is even bordering on bad advise. While I know some people prefer the weathered teak look on all their teak (or just prefer not to maintain it). I'm not one of those. For the cockpit sole, the teak is just that and I don't plan to change it. If I had teak decks, the same would go. But this area is not used for any major foot traffic so varnish it is. Oil BTW, just attracts dirt and would need monthly cleanings and re-oiling and never looks that great IMO. Same goes with Cetol, might as well paint it if you go that route. Again, my opinion.
As for having to do this all over again in a year, well, not quite the case. Sure, if I re-varnish and don't maintain it, then that statement may be true. But properly covered and bi-annually light sanding and re-coating should give me many many years without having to re-strip the varnish.
Maybe I should have stated I'm a contractor and have experience with many a tool and actually enjoy these projects. I just haven't had to remove varnish from caulking before.
I do thank you for your opinion though.
GMFL is offline
post #14 of 29 Old 02-25-2014
I have varnish on my coaming, but it doesn't cover separate media with different expansion rates along the same coating. It's not a good idea to use varnish over teak and caulk alike.
Jeanneau 54DS
post #15 of 29 Old 02-25-2014 Thread Starter
Large Member
GMFL's Avatar
I do understand that and I will take these suggestions under consideration. However, the existing varnish has been over the teak/caulk joint for many years and there was no failure that I could see. The reason I'm stripping the varnish is that it had not been maintained so i let it go until I had time to re-finish.
Again, I do appreciate these comments, but the purpose of my thread is to get suggestions on removing the varnish from the caulk. You and others have offered suggestions and I welcome them all. But... ITS GETTING VARNISH!
GMFL is offline
post #16 of 29 Old 02-25-2014
Classic30's Avatar
Dock
FWIW, I agree totally.
If it were my boat, I'd be leaving it bare.. as it was most likely intended to be.. but to each their own.
post #17 of 29 Old 02-25-2014
Classic30's Avatar
Dock
Message received, loud and clear.
...but if you really must varnish it, do yourself a favour and put the varnish down before re-doing the caulking.
post #18 of 29 Old 02-25-2014 Thread Starter
Large Member
GMFL's Avatar
Curious, why would you suggest that? All common sense (and practice) would suggest otherwise.
GMFL is offline
post #19 of 29 Old 02-25-2014
Classic30's Avatar
Dock
It's fairly simple really: Firstly, if you varnish right over the whole thing, the varnish will crack along the edges of the caulking as the timber moves allowing moisture to get under it. Secondly, some varnishes (you haven't said what you're using: a tung oil base? Urethane??) aren't compatible with some caulking products, making them "melt" and stuffing the finish. Thirdly, since the caulking has a matt finish and most varnishes a high gloss.. it makes for a better finish. Fourthly, it's easier to clean up excess caulking from varnished timber than bare timber because it doesn't get into the grain. Fifthly.. no, that's enough for now.
All common sense (and practice) would suggest you leave the timber un-varnished...
post #20 of 29 Old 02-25-2014 Thread Starter
Large Member
GMFL's Avatar
What would make you think the varnish would crack? Teak hardly moves, healthy varnish is flexible, so is caulk. The caulk would have to rely on the varnish to provide a secure joint. Teak caulk is formulated to adhere to teak, not varnish. I could go on....
You could make an argument that the varnish won't adhere to the caulk. However, if that was the case, I wouldn't have started this thread.
Common sense would suggest that my boat had no exterior wood. I'm passed that though.
GMFL is offline
Teak deck caulk Minnewaska General Discussion (sailing related) 9 01-25-2014 01:17 PM
Epoxy or caulk to glue down teak cockpit seats? copacabana Gear & Maintenance 1 12-10-2012 07:46 AM
Trim teak caulk Minnewaska Gear & Maintenance 3 07-26-2011 10:20 AM
How to remove varnish & sealant from non-skid? mrybas Gear & Maintenance 2 04-19-2010 07:37 AM
Teak varnish? saurav16 Gear & Maintenance 8 09-14-2007 11:04 AM
