Need help selecting Jib Tracks. - SailNet Community
 6Likes
post #1 of 20 Old 02-24-2014 Thread Starter
ericb760's Avatar
I've decided to add tracks to my boat. Presently, I have two eyepads at mid-boat to which I attach blocks for the jib sheets. This was, apparently, the original 1969 setup, and it leaves little in the way of adjusting while under sail. My problem is in googling tracks, there seems to be a number of sizing options and I am ignorant as to the differences. Based on the size of my boat (24'), I'm looking at about 48" of track. Now, what size track would be optimal?
ericb760 is offline
post #2 of 20 Old 02-25-2014
Remember you're a womble
PaulinVictoria's Avatar
Re: Need help selecting Jib Tracks.
Pretty sure the load you want to place on it determines the size of the track you need. I'd think on a 24' you wouldn't need more than a 32mm T-track, the Harken fittings for them are good for something like 3000lbs if I remember correctly.
[edit] I think I meant to type 22mm, but I didn't. Have a look at these bits, http://www.harken.com/productcategory.aspx?taxid=460
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #3 of 20 Old 02-25-2014
Harken also offers mid range 27mm hardware. But also check Garhauer for options.
Faster is offline
post #4 of 20 Old 02-25-2014
Use this on-line calculator to find the load to expect.
Harken Genoa System Loading Calculator
ericb760 likes this.
knuterikt is online now
post #5 of 20 Old 02-25-2014
I don't discuss my member
zz4gta's Avatar
Are you doing pin stops or adjustable genoa cars?
Merit 25 # 764 "Audrey"
zz4gta is offline
post #6 of 20 Old 02-25-2014
no longer reading SailNet
Alex W's Avatar
1" (25mm) track with adjustable pin stops is what is common on most 24-30' boats that I've seen.
If you are starting from scratch then ones with cars that are adjustable under load would be a nice upgrade. Practical Sailor did a review of such systems in the last year.
christian.hess likes this.
Alex W is offline
post #7 of 20 Old 02-25-2014 Thread Starter
ericb760's Avatar
Not sure that I understand the difference. My experience is with cars that have a spring loaded pin that locks in to the track.
ericb760 is offline
post #8 of 20 Old 02-25-2014
Bristol 45.5 - AiniA
You can get adjustable tracks that allow you to move the genoa under load. More expensive and more complicated, extra line on deck, but handy if you are into making frequent adjustments. Look at Garhauer, much cheaper than Harken and very solidly built.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #9 of 20 Old 02-25-2014
This picture show the principle
(Source Barton Marine - Tech Info - T Track and Genoa cars - Fitting Towable T Track)
post #10 of 20 Old 02-25-2014 Thread Starter
ericb760's Avatar
Originally Posted by knuterikt View Post
That looks more complicated than my needs require...
ericb760 is offline
Genoa/Jib Tracks andrewoliv Gear & Maintenance 15 09-28-2011 09:53 AM
Need help selecting a boat. MadMacX Boat Review and Purchase Forum 10 11-22-2010 05:26 PM
Re-bedding jib sheet tracks ceddavis Gear & Maintenance 5 10-16-2010 07:49 PM
Confused over multiple jib fairlead tracks OhioTom Learning to Sail 5 07-28-2009 12:53 PM
new pin holes in jib tracks blt2ski Gear & Maintenance 17 11-28-2008 10:21 PM
