There are so many good
furling systems available that it's difficult if not impossible to name the best.
I have installed, repaired and maintained just about every brand out there and they all have their good points and their drawbacks.
More important than the brand of
furler is how it was installed and how it is used. The problems that seem to occur most often can usually be traced back to installer error or operator error.
With every system, steps must be taken when installing to avoid the possibility of halyard wrap occuring. (by far the most common problem I encounter) Even ProFurl, with it's "wrap stop" is not immune if the luff of the sail is too short and a pennant isn't used or if someone slakened the halyard and forgot to harden it up again before sailing. Profurl also has the problem of the extrusion screws backing out as the headstay deflects because they are threaded into the extrusions instead of the connectors. Yes, even when installed with red locktite. I have seen this happen on a number of B&R
rigs.
Having said that, I still think ProFurl is a good system.
Cost seems to be one of the biggest factors in determining which system people opt for. The Hood 808, 707 are a well designed a affordable
furling system. They have utilized ideas from some of the other popular systems and have come up with an affordable and reliable system. And no, I don't work for them.
