Hydraulic ram pump driven RO system - Page 2 - SailNet Community
post #11 of 12 Old 03-01-2014
Re: Hydraulic ram pump driven RO system
Originally Posted by mitiempo View Post
I doubt that you could achieve the required psi to force the water through the membrane - about 800 psi is required.
I am the operator of 2 different RO systems one on an 80 foot westbay sunship and one at a large oceanfront residence. if memory serves they both start producing at around 400 psi. the one on the yacht (60 gph searecovery unit) operates at 600 and the large home unit (6 gallon per minute) at 800 psi.
mitchbrown is offline
post #12 of 12 Old 03-01-2014
mitiempo's Avatar
Spectra Watermakers run at about 800 psi.
Brian
mitiempo is offline
Replacing Engine Driven Water pump with electric seanreid71 General Discussion (sailing related) 17 10-13-2013 10:39 PM
Hynautics Hydraulic pump problems mcmichaelmcmahon Gear & Maintenance 1 03-29-2013 11:11 PM
Engine Driven Bilge Pump TwoD83 Gear & Maintenance 13 06-27-2012 06:22 PM
Hydraulic Pump gingram Electronics 1 01-26-2012 01:11 PM
Alternator RPMs after replacing an engine driven Refrigeration system fputman Gear & Maintenance 3 04-11-2010 10:13 PM
