Genny sleeve - Page 2 - SailNet Community
 3Likes
post #11 of 16 Old 02-27-2014
ASA and PSIA Instructor
Re: Genny sleeve
Originally Posted by barefootnavigator View Post
.... So we go to roller furling to make life easy but the weight of the all purpose sail hinders our boats sailing ability, heavy sheets, heavy cloth, luff tape and foam not to mention expense. ....
I doubt that the dacron UV shield that Doyle glued to our new 135% adds even a pound to the weight of the sail and it certainly has no effect on the general use of the sail. I'm not sure what the comment about heavy sheets or cloth has to do with furling. But I would think the cost of luff tape and foam (if you want it) is a toss up versus hanks.
That said, I still think that the furling genoa is the bestest invention for a sailor who has to leave the boat most nights. Combining with a UV shield, the system allows you to spend most of your sailing time...sailing.
sailingfool is offline
The Following User Says Thank You to sailingfool For This Useful Post:
Markwesti (02-27-2014)
post #12 of 16 Old 02-27-2014
Re: Genny sleeve
Agree completely... Sunbrella is really a piss-poor choice for a UV cover for a furling jib, the lighter adn more abrasion-resistant dacron stuff is far superior, it's a mystery to me why so many sailmakers continue to use it...
Why not just use a hank on sail that is the appropriate size with proper sized sheets and sail cloth for half the cost. Drop it on deck and stuff it in a deck bag. You might be surprised at how fast and wonderful your boat sails with hank-on sails.
Well, you might be surprised at the eminent practicality of RF for shorthanded cruising, and how wonderfully many larger boats sail with furling headsails... :-)
I doubt a guy like Brad van Liew would have made it around much quicker, using hanked-on sails...
Markwesti likes this.
JonEisberg is offline
The Following User Says Thank You to JonEisberg For This Useful Post:
post #13 of 16 Old 02-27-2014
Master Mariner
capta's Avatar
Re: Genny sleeve
Perhaps I'm missing something here but I can hank a sail on in about 5 minutes and bag it in the same. So we go to roller furling to make life easy but the weight of the all purpose sail hinders our boats sailing ability, heavy sheets, heavy cloth, luff tape and foam not to mention expense. Now finally some brilliant people are figuring this all out. Why not just use a hank on sail that is the appropriate size with proper sized sheets and sail cloth for half the cost. Drop it on deck and stuff it in a deck bag. You might be surprised at how fast and wonderful your boat sails with hank-on sails.
I have not used this system but I can tell you I'm way to lazy to use it, the end result would be more UV damage to my sailing because I would be tempted to leave them un covered till the end of my trip. What about offshore when you couldn't or wouldn't want to use this system, your sail would be at the mercy 24 hours a day for weeks on end. I'm very interested in this thread and people re results, great topic.
Your boat is what, 23'? On bigger boats, it's not quite that easy, or safe to "Drop it on deck and stuff it in a deck bag", especially in heavy weather conditions. My genoa weighs something over 200 pounds and is made of cloth that can rip your fingernails out, flogging around while I'm trying to keep it in control as I drop it.
Thank you very, very much for your suggestion, but I think I'll stick with my roller furling, which works wonderfully, by the way, and is controlled from the cockpit.
facebook.com/svskippingstone
Our Videos;
capta is offline
The Following User Says Thank You to capta For This Useful Post:
post #14 of 16 Old 02-27-2014 Thread Starter
Markwesti's Avatar
Re: Genny sleeve
I thought I would let you know how it turned out . I'm having the work done at Doyle , And they are doing it just as Sailingfool described . They explained it to me how the cloth becomes part of the sail , And not just goin' for a ride like canvas . Also work being done is a laundry job and some new tack and head webbing and check over for loose threads. Grand total $450.less tax. I still think the ATN sleeve is a good thing but not for me .
Markwesti is offline
post #15 of 16 Old 02-28-2014
Re: Genny sleeve
That's a good price for a fair bit of labor, Markwesti
Multihullgirl is offline
The Following User Says Thank You to Multihullgirl For This Useful Post:
Markwesti (02-28-2014)
post #16 of 16 Old 02-28-2014
baDumbumbum
bobmcgov's Avatar
Re: Genny sleeve
BTW, we made a snug-fitting cover similar to the ATN sleeve out of a microfiber polyester shower curtain and 28' continuous plastic zipper. Clip the spi halyard to the grommet at the top, start the zipper, and pull halyard with one hand while holding zipper with the other. I'd stop every 5' or so to snap a ball bungy around the assembly just above the sheets. Totally eliminated billowing or chafe. Performed this task on a mooring in 35kt winds, many times. Added maybe 4-5 minutes to putting the boat to bed. The cover lasted two seasons in some of the most brutal UV and winds you can imagine, with no harm to the sail; then the material got fragile & started to tear a bit. We'll cut up another $12 K-Mart shower curtain and re-use the zipper. I'm afraid the two grommets are a write-off.
mooring
Sunbrella has excellent lifespan, good UV blocking, and lots of colors if you like that look. But it is too heavy for smaller sails or light conditions. UV dacron is still a sacrificial material, and it will need to be overlaid or replaced every few years. That's a fair whack of time and/or money. The advantage of a sleeve is that it does not change the sail at all and can be replaced when needed w/out involving a canvas shop or sail loft. They do add a bit of work, tho, and on windy days it is easier for two people to rig it. (Unrigging it is stupid easy, right down the fore hatch it goes.) Another benefit of the sleeve is that it helps contain the rolled genoa and prevent it from opening on a mooring or in a slip during a storm. Yes, positively cleating the furler line and maybe putting a couple bungies around the genoa will accomplish much the same, but it is another line of defense. May add a bit more windage; not much.
Buccaneer18, Grainnia
SJ21, Diarmuid
Albin Ballad 30, Fionn
bobmcgov is offline
The Following User Says Thank You to bobmcgov For This Useful Post:
Vectran sleeve for anchor rode? One General Discussion (sailing related) 144 04-07-2013 01:11 AM
spinnaker sock/sleeve Dcneuro Bristol 0 07-17-2010 07:54 PM
ATN Genoa Sleeve (Sun Shield) nparadis5476 Gear & Maintenance 3 08-13-2008 04:47 PM
Sailing: Kevin has a surprise up his sleeve (New Straits Times) NewsReader News Feeds 0 11-30-2006 04:16 AM
Spinnaker Sleeve vs Chutescoop jkoutras Learning to Sail 1 04-17-2002 11:02 AM
