Adapting an automobile tachometer - SailNet Community
 1Likes
post #1 of 11 Old 02-27-2014 Thread Starter
Hy
The tachometer on the motor panel of my volvo 2030 engine dont return to zero after switching out the motor.
A friend with a similar volvo installed an automobile tachometer.
The problem is that the readings do not correspond to the real rpm.
Any idea of how to adapt such a tacho?
Thanks in advance
Saludos
Ulfilas is offline
post #2 of 11 Old 02-27-2014
Master Mariner
capta's Avatar
Re: Adapting an automobile tachometer
Gas engine and diesel engine tachs are not interchangeable. Sorry, you're going to have to bite the bullet on this one.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #3 of 11 Old 02-27-2014
not to say obvious things, but have you checked the wiring? usually that means bad ground.
tachs are tachs.... auto or otherwise. just have to calibrate it. need more info to get in deeper
1967 Bristol 29 #35
Rozz is offline
post #4 of 11 Old 02-27-2014
Geoff54's Avatar
Tachs can be mechanical (becoming rarer but there are still a few about) or electronic.
Electronic tachs can be driven of off the ignition pulse (won’t work with diesel) or off an electronic trigger.
The trigger can pulse at engine RPM (Crankshaft trigger), half engine RPM (camshaft or sometimes distributor trigger) or sometimes some other shaft/speed.
The tach pulse can be send directly or modified via the ECU.
Bottom line is that you need to know what you are dealing with and match the tach input for the tach you are using.
edit: There are also different types of trigger. Sorry!
The easy way is to use the correct tach.
"The great thing about the internet is that you can quote anyone and no one will bother to check the source" - Aristotle
Geoff54 is offline
post #5 of 11 Old 02-27-2014
oh yeah, i guess i should been more specific... what Geoff54 said knowing what kind of trigger you have then u can get whatever tach matches, but need more info.
think urs is an alternator type? have to set the settings on new tach to match. have to know crankshaft and alt pulley diameter then ref. instructions. most have dipswitch or selector switch
1967 Bristol 29 #35
Rozz is offline
post #6 of 11 Old 02-27-2014
Maine Sail's Avatar
Originally Posted by Ulfilas View Post
Hy
Thanks in advance
Saludos
The MD2030 uses an alternator sensed tachometer. They are often called "diesel tachs". They use the AC pulses from the alt for their signal and require calibration to the alt. Many companies make replacement alt sensed tachs..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #7 of 11 Old 02-27-2014
Asleep at the wheel
jimgo's Avatar
Maine, how hard is it to add a tach to an engine? My Universal 5416 doesn't have one, and I'd really like to get a better feel for the engine speed.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #8 of 11 Old 02-27-2014
Sea Sprite 23 #110 (20)
mad_machine's Avatar
when you say it does not return to zero.. does it just stay where it is, or does it drop to a point close to zero and stay there?
It might be worth taking it apart and doing some cleaning. Tachs are a relatively simple device with some very lightweight parts. a little bit of corrosion or dirt could easily stop the needle
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #9 of 11 Old 02-27-2014
deltaten's Avatar
Send a message via Yahoo to deltaten
Auto Meter ## 2888 diesel tach. Comes with strap on sensor for alternator.and instructions to adj for correct rpm. Says that it might not zero whenn off.
IIRC,eBay prides as low as $nintey nine.I ndeed one too, so looking hard.this one is external deck mount, in it,s own "can", but could be adapted to flush surface?
Some work off injector pulse, buthaven't found one for three cylinder
t
jimgo likes this.
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
The Following User Says Thank You to deltaten For This Useful Post:
jimgo (02-27-2014)
post #10 of 11 Old 02-28-2014
Maine Sail's Avatar
You just need an alt with an "AC Tap" or stator tap and a diesel type tachometer. Any alt show can re-wire your alt to have a stator tap for an alt.. You will also need a digital photo tach for calibration to your engine RPM. Not difficult, just requires some patience..
______
The Following User Says Thank You to Maine Sail For This Useful Post:
jimgo (02-28-2014)
Automobile Diesel Engine Conversion Kielanders General Discussion (sailing related) 30 12-20-2011 02:20 PM
Type/Size of Automobile needed to tow various boats blastoff General Discussion (sailing related) 10 09-24-2006 11:25 AM
Adapting foreign mast for P18? OKKID Gear & Maintenance 0 07-01-2003 11:31 AM
Adapting Power Sue & Larry Gear and Maintenance Articles 0 12-20-2001 07:00 PM
