Hood furler question - SailNet Community
 2Likes
post #1 of 13 Old 02-27-2014 Thread Starter
rbyham's Avatar
I am trying to better understand how my furler is rigged. I recently had to increase the length of the furling line in order to fully furl a newly installed larger genoa.
In the process of removing the sail and taking additional line wraps around the furler, I noticed that the aluminum extrusions were separating at a joint about 4' up from the deck. I could slide the extrusions together by hand and they do not appear to be damaged but seeing the separation like that made me wonder if I have a problem. The unit seems to work fine in terms of furling and unfurling the sail but the ability for the extrusions to move vertically left me concerned. Any thoughts?
See pic below. Joint in question about 4' up from deck
rbyham is offline
post #2 of 13 Old 02-28-2014
Once known as Hartley18
Classic30's Avatar
Dock
Re: Hood furler question
Do you have a better pic of the problem? What model furler is it??.. looks a bit like a Profurl from a distance.
The extrusions should be clamped at the top and it's quite normal to have a bit of play vertically... but is there much play in the extrusions rotationally?? ie. if you try to twist a lower one by hand. I'd be more concerned about that.
A close-up of the "separating" joint would help a lot in working out whether you have a problem or not.
Classic30 is offline
post #3 of 13 Old 02-28-2014 Thread Starter
rbyham's Avatar
I believe it is a seafurlurl. Let me try to get a better pic when I get back to boat on Monday. There is zero rotational flexing. It is all vertical. But the joint in the picture can open to about a 2" gap. Can you elaborate on ends being clamped. The Furler cameI with the boat and beyond stepping the mast and Tightening the rigging I know very little about the technical aspects of the furler.
rbyham is offline
post #4 of 13 Old 02-28-2014
From my limited knowlege of furlers, the sections are ussually locked together IE screws and a splice between them. This doesn't sound right.
benesailor is offline
post #5 of 13 Old 02-28-2014 Thread Starter
rbyham's Avatar
I did find one other pic on my phone. Not real great either but might help. The joint in the picture is darker colored. In this pic it is separated about 1".since hoisting the new 135 I can slide it about 2" open.
rbyham is offline
post #6 of 13 Old 02-28-2014
Sailor
Gladrags1's Avatar
It sounds like you have play in the sections where the extrusions are connected. This is not normal. There is an insert between extrusion units to join them and make them turn as a unit. There should be some type of set screw, probably with an Allen head, holding them together. I bet the screw is there but loose, preventing vertical seperation completely but not tight enough to keep them in place. Time for ladder or bosuns chair work!
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #7 of 13 Old 02-28-2014 Thread Starter
rbyham's Avatar
Sounds like it is time to understand exactly how the extrusions connect and work... The idea of an insert sounds right. I recall seeing something like that when rigged. Did not see a screw as part of that picture but that does mean it wasn't there. Thanks all...
rbyham is offline
post #8 of 13 Old 02-28-2014
Sailor
Gladrags1's Avatar
Why not check directly with Hood. It would be good to figure out what model you have. There are a lot of Hood SeaFurl units out there. Perhaps it was one of them? Look them up on the internet, Pompanette is their parent company and contact them for a manual. They will, I'm sure, gladly send you one. Then you will know how the extrusions are connected and be able to get replacements if available.
Tod
Mandolin, Bayfield 36 out of Rock Creek, Chesapeake Bay.
Sent from my iPhone using Tapatalk
Mandolin
Bayfield 36
post #9 of 13 Old 02-28-2014
JimMcGee's Avatar
If you can find the model number on the drum you can probably find the manual online.
On my Hood furler the sections are joined with delrin allen head screws.
95 Catalina 30 Island Time
ďThe sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #10 of 13 Old 03-02-2014
Classic30's Avatar
Dock
The older 'Seafurl' used rivets, but if it's the 'Seafurl II' the sections are held together with a 'button lock' system - basically joiners with a button on either end that fit into holes in the track sections. The joiners are held in places using 'splice pieces' supported by an inner bearing tube around the wire forestay. It is not uncommon for the splice pieces to slide down inside the furler allowing the buttons to separate, but this would usually allow some amount of rotation also, so what you're describing shouldn't be possible.. Maybe something is missing completely?
A close-up photo of the section join in question would be a huge help in nutting this out.
PS: I have a copy of the 'Seafurl' and 'Seafurl II' manuals and could email them you if you want but they are very difficult to understand and I seriously doubt they will help with this problem.
Forestay adjustment with Hood drum roller furler Nilaya Gear & Maintenance 8 05-17-2015 11:57 AM
Need help with Hood furler Capt Ron1 C30 1 06-16-2014 03:07 PM
Old Hood roller furler THEFRENCHA Gear & Maintenance 4 08-15-2013 09:54 AM
Hood roller furler RayWood Gear & Maintenance 6 02-24-2011 05:08 PM
HOOD Stoboom, mainsail furler Vitamin Gear & Maintenance 11 09-08-2009 06:36 AM
