Thru Hull Plug? - SailNet Community
post #1 of 2 Old 02-23-2006 Thread Starter
Thru Hull Plug?
A no longer used thru hull (at one time it was for a head that has been de-commisioned).... it's closed. It's capped. Close inspection shows it's all still in good shape.
Someone suggested additionally putting a rubber plug in it from the outside..... one of those "one more line of defense" ideas. Sure it would not be water tight but it might reduce the flow a bit.
Good idea? Bad idea? or Useless waste of time idea?
Tree is offline
post #2 of 2 Old 02-23-2006
catamount's Avatar
Next time you have the boat hauled out, why not pull the thru-hull and fiberglass over the hole, getting rid of the potential problem permanently?
catamount is offline
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
Hull speed and wide sterns Jeff_H Boat Review and Purchase Forum 24 11-21-2006 11:58 PM
Thru Hull Replacement Stormer_2003 Gear & Maintenance 1 09-13-2004 11:22 AM
Thru Hull Replacement Stormer Gear & Maintenance 4 08-03-2004 08:21 AM
Hull layup Irwin32 Boat Review and Purchase Forum 2 06-22-2002 08:14 PM
