Cold beer a Must - SailNet Community
 6Likes
  • 2 Post By Multihullgirl
  • 1 Post By fryewe
  • 3 Post By MarkofSeaLife
post #1 of 10 Old 02-28-2014 Thread Starter
OUPV 25 Ton
CaptainRahnn's Avatar
Cold beer a Must
Considering an icebox conversion for my cal 34. I'm interested in some opinions on brands and power consumption.
Thanks Ron
1976 Cal 34 mk2
"Shameless"
CaptainRahnn is offline
post #2 of 10 Old 02-28-2014
Re: Cold beer a Must
This fella knows all and tells all. Start with his site, read his books
Kollmann Marine
Group9 and Markwesti like this.
Multihullgirl is offline
post #3 of 10 Old 02-28-2014
Cruising at a snail pace
I have an Adler Barbour that is a spill over system (it's a freezer really) with a pretty large freezer and frig. I keep the freezer about 20 degrees F and the frig about 35 degrees and on average it uses 60AH/day based on solar panel log during the week.
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
post #4 of 10 Old 02-28-2014
Mermaid Hunter
SVAuspicious's Avatar
Keel coolers (Frigoboat or Isotherm SP) are the most electrically efficient you're going to find. Quieter (no sea water pump) and lower maintenance.
I agree that Richard Kollman has expertise and shares it that is hard to match.
SVAuspicious is offline
post #5 of 10 Old 03-01-2014
norahs arc's Avatar
We use a Domatic cooler/freezer. It is 12/24Volts DC or 110Volts AC. We run it on DC on the boat as a cooler with the temperature set at 1 degree C (Appx 34 degres F).
LOVE IT! Uses very little power and is almost silent.
At home in our northern winters we set it to -17 degrees C ( Appx. 2 degres F) and use it as a second deepfreeze on 110Volts AC. Have had it two years with no problems.
Catalina 27 Aft. galley, dinnet L/O
Update - Sold Norah's Ark Buying A 24'Shark
Saint John NB
Canada
norahs arc is offline
post #6 of 10 Old 03-01-2014
We have one of these, for day use it might work. Does exactly as is says, holds at 40 degrees, or a bit more, less than the outside air. Draws about 5 amps, IIRC. Pre chill with the 110 volt converter at home, plug it in to the car while driving to the boat and you are good to go.
http://www.amazon.com/Koolatron-P20-Compact-Kooler/dp/B00009PGNS/ref=pd_sxp_grid_pt_0_2
IIRC, they have different sizes
Paul T
dabnis is offline
post #7 of 10 Old 03-01-2014
fryewe's Avatar
Good English beer is good without refrigeration...maybe easier and more cost effective and less of a headache to switch beers than to add a reefer.
trantor12020 likes this.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
post #8 of 10 Old 03-01-2014
Take one can of beer put can into sock dip sock in water hang sock under boom,half an hour cold beer.
harmonic is offline
post #9 of 10 Old 03-01-2014
MarkofSeaLife's Avatar
Dock
I'd need 24 socks.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #10 of 10 Old 03-03-2014
trantor12020's Avatar
Originally Posted by MarkofSeaLife View Post
I'd need 24 socks.
And thats only for the morning
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
Tags
conversion , icebox , refrigeration
I hope the beer was cold cardiacpaul Learning to Sail 12 12-28-2006 04:33 PM
Cold beer please! Stede Gear & Maintenance 6 11-05-2002 07:56 PM
