Plastic transducer leaking - Page 2 - SailNet Community
post #11 of 12 Old 03-03-2014
Re: Plastic transducer leaking
The threaded ring should not have water under it. There should be two o-rings around the transducer body that seal against the tube and keep the water out. Probably these o-rings need to be replaced. Put some Super Lube on the new o-rings to make it easier to slide the transducer in and out. If you have haul out facility nearby you can try pulling the transducer while in the water. If things go bad just stuff the hole and haul out.
Transmitterdan
1995 Valiant 42
transmitterdan is online now
post #12 of 12 Old 03-03-2014
Also dig around in all the lockers/drawers you rarely look into.. you may well find a blind plug for that paddlewheel - swapping that while in the water is exciting, but easy to do. If it's Orings are OK you can leave the plug in place until you do the re and re...
Faster is online now
Leaking transducer through hulls rhsanborn Gear & Maintenance 14 07-16-2012 03:53 PM
Plastic Hatch emiller775 Gear & Maintenance 8 02-03-2011 02:10 PM
Plastic paint for tired looking plastic parts Goodnewsboy Gear & Maintenance 3 01-01-2007 06:15 AM
