Plastic transducer leaking - SailNet Community
post #1 of 12 Old 02-28-2014 Thread Starter
I got a (new to me) boat, and was noticing a lot of water in the bilge, so I covered the area with talcum powder.
Good news - I think I found the leak (circled in red)
Bad news - the weird plastic transducer is leaking. It's under the sofa in front of the water tank, and I think the water is running down from that area into the bilge. It's a paddle-wheel type that isn't even connected. I'm annoyed because I was really close to replacing the entire thing with an actual working transducer when I was hauled out but didn't.
You can see in the picture where it is leaking, around the top of the 'ring'.
I am going to haul out again in 6 months and plan to replace the entire thing with a transducer that actually works, so is covering the entire top with marine sealant/WaterWeld, waiting till it dries and covering THAT with marine tex a good idea? I don't care about fixing it in - the transducer I want to replace it with uses a 2" hole (current one is 1.5") so the entire thing will be cut out anyway.
Liveaboard on a 1980 36' Hunter
alctel is offline
post #2 of 12 Old 03-01-2014
Re: Plastic transducer leaking
If it's a removable paddlewheel transducer have you tried tightening that top ring? It's designed to be removed and replaced with a plug for haulout. Could be it's simply not tightened up, or needs a new seal/gasket.
But you're right.. in hindsight you should've changed it when you could !
Faster is offline
post #3 of 12 Old 03-01-2014
bpgoll's Avatar
Well noted sir
Thanks
bpgoll is offline
post #4 of 12 Old 03-01-2014
DearPrudence's Avatar
Can't you just use an in hull transducer as opposed to a thru-hull one? That way you can avoid drilling holes altogether.
DearPrudence is offline
post #5 of 12 Old 03-01-2014
I think he's talking about a paddlewheel speed transducer, not depth....
Faster is offline
post #6 of 12 Old 03-01-2014
Ticon 30
dbruce85's Avatar
I had the same situation on a previous boat, It was a very slow leak around the ring. I tried different Marine Sealants around it, but it kept leaking.
I used some black roofing compound that I had at home, the kind you can use when the area is wet. It wasn't pretty but was in a hidden location. I know that would make most old salts cringe, but did stop the water. ( In retrospect, there was a wooden block on the inside of the hull, sometimes when the wood gets wet and swells a bit the leak stops, not that that is a good situation but it gets you thru until you can fix it properly). I installed a new transducer during my next haul out, the black compound came off easy with some varsol.
dbruce85 is offline
post #7 of 12 Old 03-01-2014
Master Mariner
capta's Avatar
It's a bit late now, don't you think? He already has a 11/2 inch hole in his boat. And it's leaking, so it needs to be attended to. Replacing it with another transducer is a lot easier and cheaper than trying to fill a 11/2 inch hole in a boat.
facebook.com/svskippingstone
Our Videos;
capta is online now
post #8 of 12 Old 03-01-2014 Thread Starter
Can you remember the product name? I've used water weld but it doesn't seem to hold
alctel is offline
post #9 of 12 Old 03-02-2014
Ticon 30
dbruce85's Avatar
No I can't remember the brand, but it was a liter can of black roofing compound. The type that claim they will work in wet conditions. The water was not rushing in, only a trickle. However it did seal it for the season.
dbruce85 is offline
post #10 of 12 Old 03-02-2014
I've seen these leaks before. They are hard to stop. Encapsulating it ussually doesn't work because the pressure builds up and blows it back open. The sooner you can haul out the better.
Gooping it may slow it down.
Don't know about roofing tar. I've had good luck with a product called "Through the Roof"
Through the Roof! - Sashco - Roofing Caulk
Once it dries its a absolute PITA to get off. So beware.
benesailor is offline
Leaking transducer through hulls rhsanborn Gear & Maintenance 14 07-16-2012 04:53 PM
Plastic Hatch emiller775 Gear & Maintenance 8 02-03-2011 03:10 PM
Plastic paint for tired looking plastic parts Goodnewsboy Gear & Maintenance 3 01-01-2007 07:15 AM
