Mold and asthma - SailNet Community
 1Likes
post #1 of 16 Old 03-03-2014 Thread Starter
Mold and asthma
We are newbie sailors looking to buy a used boat (34'-40') for coastal cruising in New England with friends who have sailed more in warmer climates. One of us has asthma and all the boats we have seen (all in colder months) have had mold and mildew in the cabin. I was wondering if there are sailors out there who have asthma and can comment on dealing with mold on a sailboat that is used about once every 1-2 weeks. Are there things that can be done to minimize the problem or manage it? I've called a cleaning/detailing company and they said they can clean the cabin for $600-$800 and if needed remove any ductwork and clean it for about $1600-$1800. Do you think this would deal with the problem? Would it come right back? Thanks for any advice!
capt_rk is offline
post #2 of 16 Old 03-03-2014
turophile
Re: Mold and asthma
Ventilation is the key to keep the moisture and thus the mold/mildew under control. Add a couple of solar vents like the Nicra, set one to pull and one to push at opposite ends of the boat. Prop up cushions and open lockers when you leave. And keep your bilge dry.
I have mold / mildew allergies and those things are enough for me to have avoided problems so far.
mr_f is offline
post #3 of 16 Old 03-03-2014
snake charmer, cat herder
zeehag's Avatar
Re: Mold and asthma
the two great V s of sailing...VENTILATION and VINEGAR.
i have cough variant asthma and i use vinegar fro cleaning everything on boat.. not always full strength...as i do with mold, when necessary.
it works. i dont die. is all good. mold even stays away
formosa 41, cruising tropics
zeehag is offline
post #4 of 16 Old 03-03-2014
guitarguy56's Avatar
Re: Mold and asthma
I have asthma and had to thoroughly de-mold all areas of the inside cabin and outside on the deck as you'll bring in mold spores inside with Lysol/vinegar. I removed all cushions that had any mold spores and made either new cushions/covers or sterilized any cushions I did not buy new... I then reupholstered all fabric coverings... clean, clean clean is what you need to do... it may have smelled like a hospital but I never had a problem sleeping on the boat. Dehumidifiers work great and I used a fan to run air out of the cabin and get cabin air flow thru. When out of the boat for over a week I took all the cushions and stood them upright with a gap between them to allow air flow (fan still on)... molds love moisture and dark humid places.
guitarguy56 is offline
post #5 of 16 Old 03-03-2014
RichH's Avatar
Re: Mold and asthma
Mold and funguses are best removed by using 'caustics' which dissolve the cells. Chlorine, clorox, vinegar only kills/stuns these cells and leaves these cells to become the nutrient sources for future species of fungal microorganisms. Lye soap, lye, or 'strong' alkaline soaps and detergents including TriSodiumPhosphate-TSP or sodium silicate based detergents are 'dissolvers' of fungal cells.
Funguses spread by the release into the atmosphere their spores; dead or removed funguses generate no spores.
Mechanically you have to 'scrub' more than visible surfaces; you must remove all the growing fungals from all the 'hidden' spaces: under the sole, under the 'pan liner', bilge, the WATER TANK VENT HOSE, etc.
Once all the interior spaces are 'thoroughly cleaned', then consider to 'spritz' (not on painted or varnished surfaces) one of the sodium silicate detergents (Roll-ON™ or Tuff-eNuff™) or http://www.amazon.com/3M-Marine-Mildew-Block-fl-Ounce/dp/B000BEXWVY/ref=sr_1_1?ie=UTF8&qid=1393882806&sr=8-1&keywords=3m+marine+mildew+block ... and simply let dry - dont wipe off !!!! This will be a modern equivalent of 'white-washing' - a sure-fire method of mold/mildew prevention discovered by our far distant ancestors - caustics !!!, which deactivates mold/mildew/fungal spores !!!!!!! .... and no matter what the internal 'humidity or air-flow' inside your boat.
If you are sensitive and/or reactive to molds/mildews/funguses, be SURE to wear a RESPIRATOR, goggles, etc. when cleaning. NEVER EVER 'clean' mold/mildew/fungus when it's 'dry' as you will only release and spread the spores into the atmosphere; before cleaning always wet it down (water, clorox, sodium silicate, etc.) to prevent/lessen the spread of the SPORES and prevent you from aspirating them deeply into your lungs --- advice for even 'healthy' folks.
If your 'sensitivity' to mold, etc. is high, consider to hire a 'dairyman' or someone from a 'dairy maintenance' company to do the bulk of the cleaning and disinfection for you (but dont allow them to 'treat' any painted or varnished surfaces - you do this as for sure theyre going to be using 'strong caustics'.).
For long term storage/closure of your boat, consider to use "Para-formaldehyde" crystals .... put a measure of crystals in a plastic pan, as you hold your breath as you QUICKLY close up the boat without breathing. When returning, open the boat to 'air out' for a long time before reentering. Obviously para-formaldehyde crystals wont be available in states that prohibit the use of common 'chemicals' by consumers. Para-F is deadly to mold/mildew, and human lung tissue too.
CatMan22 likes this.
RichH is online now
post #6 of 16 Old 03-03-2014
Dirt Free
boatpoker's Avatar
Re: Mold and asthma
ozone generator, solar powered vents, 20yrs liveaboard never a single spec of mold
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #7 of 16 Old 03-03-2014
JimMcGee's Avatar
Re: Mold and asthma
RK, my wife has asthma. We did some basic things that made an immediate difference, and some larger jobs that made a big difference long term.
When we first got the boat I steam cleaned all the cushions and we did a general cleanup inside to get rid of any obvious mold and mildew.
Next I scrubbed out the bilge. This helped with any odors. She was OK that first summer.
Longer term I got the Nicro fan in the v-berth working. Nicro makes solar powered fans that run/charge during the day and then run on the charged batteries at night. We also have dorade vents that allow air into the boat. Air comes in through the dorades and is exhausted out by the Nicro fan so there is always air movement on the boat when we're not there.
Next I replaced the shaft packing with a dripless shaft seal. This means the bilge is always dry. No dampness means no mildew.
Finally we keep Kanberra Gel in the cabin and head which is surprisingly effective.
Since making these changes we no longer have any "boat smell".
Best of luck,
Jim
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #8 of 16 Old 03-03-2014
pdqaltair's Avatar
Re: Mold and asthma
The US EPA disagrees with you, as does every other health authority, it seems.
Table 1. Ozone Heath Effects and Standards
Health Effects Risk Factors Health Standards*
Potential risk of experiencing:
Decreases in lung function
Aggravation of asthma
Throat irritation and cough
Chest pain and shortness of breath
Inflammation of lung tissue
Higher susceptibility to respiratory infection Factors expected to increase risk and severity of health effects are:
Increase in ozone air concentration
Greater duration of exposure for some health effects
Activities that raise the breathing rate (e.g., exercise)
Certain pre-existing lung diseases (e.g., asthma)
The Food and Drug Administration (FDA) requires ozone output of indoor medical devices to be no more than 0.05 ppm.
The Occupational Safety and Health Administration (OSHA) requires that workers not be exposed to an average concentration of more than 0.10 ppm for 8 hours.
The National Institute of Occupational Safety and Health (NIOSH) recommends an upper limit of 0.10 ppm, not to be exceeded at any time.
EPA’s National Ambient Air Quality Standard for ozone is a maximum 8 hour average outdoor concentration of 0.08 ppm (see - the Clean Air Act - Title I | Clean Air Act | US EPA)
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #9 of 16 Old 03-03-2014
pdqaltair's Avatar
Re: Mold and asthma
And while ventilation is good, a small dehumidifier is better.
And following on RichH's thread...
One Penny Mildew Spray - Inside Practical Sailor Blog Article
The key is light even application and NOT removing it.
post #10 of 16 Old 03-03-2014
Dirt Free
boatpoker's Avatar
Re: Mold and asthma
No they don't disagree with me if you use it properly. Our Heavenfresh 300C air purifier with HEPA filter, UV filter, charcoal filter, ion generator and ozone generator ran 24hrs/day except for the ozone which was only engaged while not on board.
Mold LOCKNUT General Discussion (sailing related) 19 12-07-2013 10:11 AM
Mold SVArgo Cruising & Liveaboard Forum 29 01-29-2012 09:46 AM
Mold Problem markcammiade Introduce Yourself 1 01-23-2011 04:10 PM
mold inhibitors? dnf777 General Discussion (sailing related) 1 08-01-2010 10:54 AM
Asthma Treatment William Mahaffy Seamanship Articles 0 11-17-1999 07:00 PM
