02-28-2006
Señor Member
Originally Posted by lightyear22
"Lucky enough it is not leaking, for now."
Eventually it will, after the core rots, allowing trapped water to migrate through the core to the lowest level penetration in the bottom layer of deck-coring. This may be a headliner attachment, light fixture, or nearby hatch.
The quick-fix cure would be to remove the stancheon, and inject epoxy into the core surrounding the stancheon base. Then re-bed & screw the stancheon base to the deck, after epoxy is cured. The best fix is to remove the rotted core, dry out & reglass both inside & outside membranes.
True Blue . . .
sold the Nauticat
