Halyard Colors - Is there a standard? - SailNet Community
post #1 of 3 Old 03-02-2006 Thread Starter
I was wondering if there is set colors for halyards. I see alot of red fleck for mains, and blue fleck for genoas. Is there a stardard or is it just user preference. I have heard people say make sure you color code your lines. For me I will know the color code on my boat, but someone coming along will not, they might even use blue fleck for the main - you know what I mean. Is there colors for a spin top lift? How about a 2nd genoa? Or even the Spin halyard? Does anyone know or where a reference point would be?
Thanks
Andrew
lightyear22 is offline
post #2 of 3 Old 03-02-2006
I'm not aware of a standard, and every boat I've been on is different. Maybe that's why I've seen sheets of preprinted self-adhesive labels in the stores, with the names of typical lines.
That being said, even in the absence of a standard, I've got my lines color coded. It's a lot easeir to tell a new crew member that the genoa halyard is while with blue flecks than "second from the left on the starboard clutch".
Mark
One Step Closer
Lake St. Clair Michigan
BeneteauMark is offline
post #3 of 3 Old 03-02-2006
paulk's Avatar
Color coding
We have our port and starboard spinnaker halyards done in red & green (respectively) covers. Our other spinnaker strings are red fleck, jib sheets & halyard are blue fleck. Main isn't colored. Sometimes it comes down to whatever color they have enough of at the store. If you race overnights, it doesn't make too much difference anyway.
paulk is offline
halyard @ top of mast aeb0508 Gear & Maintenance 38 02-07-2009 11:15 AM
halyard working load Randolph Bertin Learning to Sail 1 10-27-2003 11:12 PM
How to retrieve a halyard from masthead??? gwp General Discussion (sailing related) 8 05-29-2003 05:10 AM
main halyard Sailmale Gear & Maintenance 5 06-20-2002 09:25 PM
Standard Survey Format? Bilge_Scum Boat Review and Purchase Forum 1 09-18-2001 05:25 AM
