How to fix an older 12-v flourescent light? - Page 2 - SailNet Community
 3Likes
post #11 of 14 Old 03-13-2014
Learning a bit every day
FinallySailing's Avatar
Re: How to fix an older 12-v flourescent light?
Last week my son noticed smoke coming from the fluorescent light that the po had put in to run when on shore power. The ignitor had just done that - it overheated and was melting. Got a nice LED striplight to put in its place today. All my 12V cabin lights have been replaced with LEDs. 10 for 5 SMD panels and a 12V voltage controller. Simple to install in just an afternoon. Best project so far this season
Yet my heart hammers now, yearning anew
wanting the steep salt-water road
longing with lust to roam rough seas, alone
to seek out some far foreign shore
From "The Seafarer", an Anglo-Saxon 10th century manuscript.
FinallySailing is offline
post #12 of 14 Old 03-13-2014
"I'm sure it must be cheaper to repair than to replace."
Stay out of Vegas and away from the horse tracks.(G)
If it was a top-quality light, it might have had an electronic ballast. Otherwise there's a small metal can (the starter, usually with a pinhole in it so you can see a little purple lamp flickering when that works) and there's a ballast coil somewhere, often oozing black goo by now.
And it is almost always the ballast or the bulb that is bad. Bad bulbs will have blackening at one or both ends. Bad ballasts usually make the lamp flicker before they quit. Either way...
Ballasts often cost more than complete fixtures do, that's just the way it is. Good ballasts are damned expensive and cheap ones are junk. So I'd join the choir and say go looking for LED replacement fixtures. Might cost less, certainly will use much less power and last longer without all the usual problems. Skip the real cheap ones, since cheap is cheap and that's a problem with everything these days.
hellosailor is offline
post #13 of 14 Old 03-13-2014
sailvayu's Avatar
Here is a video I did on converting a fluorescent to LED. It is one of my early ones so not great but might help.
Capt. Wayne Canning, AMS
sailvayu is offline
post #14 of 14 Old 03-13-2014 Thread Starter
Wow--talk about unanimity of opinion.
Thanks to all of you for your advice. It never occured to me but LED's look like an elegant solution. I'll gut the lamp case and retrofit it with those.
I would have spent hours looking for replacement parts that apparently would have been either costly or junk, and ended up with outdated equipment. I'm glad I asked you guys.
Great video, Capt. Canning.
Thanks again to all of you for replying.
John V.
VallelyJ is offline
Flourescent light fixture brokesailor Gear & Maintenance 14 05-15-2012 04:44 PM
How do I fix this? BarryL Gear & Maintenance 3 05-07-2012 06:17 PM
Tri-color Steaming masthead light as only nav light? Perithead Gear & Maintenance 110 09-18-2011 12:53 PM
steaming light, running light, wiring yzlian Pacific Seacraft 4 03-24-2011 09:44 AM
light winds and older sails ... mikehoyt Racing 6 07-06-2004 07:09 AM
