How to fix an older 12-v flourescent light? - SailNet Community
 3Likes
post #1 of 14 Old 03-12-2014 Thread Starter
One of the 12v flourescent lamps that I'm sure came with the boat in 1979 no longer works. I don't see where it uses a plug-in ballast, so I don't know what to do to fix it. I'm sure it must be cheaper to repair than to replace.
Does anyone know to id what part is bad, and how to replace it if it's obsolete?
Thanks.
John V
VallelyJ is offline
post #2 of 14 Old 03-12-2014
Re: How to fix an older 12-v flourescent light?
If it is a 2 light fixture the ballast is typically located between the tubes under a metal cover. You might also be able to see a little silver canister. That is the ignitor and is prone to failure. . Finding parts is a hassle. Maybe it's time to replace with LED. If you like the housing a little led strip can work wonders, and it's natively 12 volt (most of the time)
Boredop is offline
post #3 of 14 Old 03-12-2014
tommays's Avatar
It belongs in your pile of old useless stuff
And replaced with something that will work well,save all kinds of electric use while lighting the boat MUCH BETTER
bljones likes this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #4 of 14 Old 03-12-2014
Bristol 45.5 - AiniA
We have installed LED strips and square fittings (4 elements) into old fluorescent figures with great success. All I used from the figure was the casing, lens, and switch. Much better light and much better power usage.
Finishing our major refit. Our trip to Newfoundland is off because it is too late. Hoping to go to the North Channel instead.
killarney_sailor is offline
post #5 of 14 Old 03-12-2014
Ditto the other posters' advice to ditch the fluorescent tubes. Look at Marinebeam.com for some good tube replacement options (if you're willing to modify the fixture to remove the ballast) and fixture replacement options (if you're not).
IStream is offline
post #6 of 14 Old 03-12-2014
Glad I found Sailnet
Bene505's Avatar
It could be the switch has oxidized. Switch it 100 times and see if it starts working.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #7 of 14 Old 03-13-2014
jsaronson's Avatar
Buy some 12 volt LED rolls on Ebay or at autozone. Connect to the switch and use the adhesive back to stick it to the metal.
Group9 and christian.hess like this.
jsaronson is offline
post #8 of 14 Old 03-13-2014
Delta-T's Avatar
+1 on going LED, but here are replacement parts...http://www.altestore.com/mmsolar/oth...t_lighting.pdf
I would verify that the problem is not power or switch related first. And, it could even be a bad bulb.
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #9 of 14 Old 03-13-2014
Group9's Avatar
That's close to what I was going to say. Do what I did. Yank it out, throw it away, and put in LED lighting where it was.
I am working feverishly toward my goal of having nothing but LED lights on my boat. With battery power, LEDs just make sense.
On the northern Gulf of Mexico.
"Best thing to do is get her out on the ocean. If anything's gonna happen, it's gonna happen out there." Captain Ron Rico
Group9 is offline
post #10 of 14 Old 03-13-2014
Tim R.'s Avatar
Definitely LED. I am in the process of converting all my Alpenglows to LED. Much cheaper to DIY than to have them do it. Only 2 left but I will likely wait to do this as a project after we leave.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
Flourescent light fixture brokesailor Gear & Maintenance 14 05-15-2012 05:44 PM
How do I fix this? BarryL Gear & Maintenance 3 05-07-2012 07:17 PM
Tri-color Steaming masthead light as only nav light? Perithead Gear & Maintenance 110 09-18-2011 01:53 PM
steaming light, running light, wiring yzlian Pacific Seacraft 4 03-24-2011 10:44 AM
light winds and older sails ... mikehoyt Racing 6 07-06-2004 08:09 AM
