G5 (5 min epoxy) vs regular West System - SailNet Community
 2Likes
post #1 of 13 Old 03-12-2014 Thread Starter
How much weaker or worse is the G5 (West System) 5 minute epoxy than the standard West System 105/205 epoxy?
With such a cold winter, I haven't completed as much epoxy work as I was hoping to and I'm getting backed into a corner to get some things done. I am thinking of doing a job which consists of:
1. applying thickened epoxy to fill in gelcoat scratches/gouges
2. Let that cure then finish sand and wash off amine blush
3. Wetting out and applying one layer of fiberglass to reinforce the area
4. Apply remaining 2 - 3 coats of epoxy
If I use 5 minute epoxy I can do this whole job in one day at 55 degrees and maybe even get a coat of pre-kote primer on. This would take a lot more time with the regular epoxy.
Is this a bad idea or this G5 stuff pretty decent?
Reefpoints is offline
post #2 of 13 Old 03-13-2014
first sailed january 2008
northoceanbeach's Avatar
Re: G5 (5 min epoxy) vs regular West System
It was ok for me. Not great. My use last year was also about 55 and humid and it wasn't 5 minutes. But once cured it was decent.
northoceanbeach is offline
post #3 of 13 Old 03-13-2014
mitiempo's Avatar
I would use standard 105/205. You won't have time to thicken the G5 before it sets. It isn't as strong either. Great for holding parts together before using 105 to coat or fillet etc.
sailordave likes this.
Brian
mitiempo is offline
post #4 of 13 Old 03-13-2014
What he said.
CS 36M DIANTHUS
sailordave is offline
post #5 of 13 Old 03-13-2014
Chastened
Ajax_MD's Avatar
The instructions also state:
Not recommended for long-term bonds subject to high loads or moisture.
It's kind of for quick, temporary repairs. I found the fully cured consistency to be a little rubbery compared to G/Flex or the standard epoxy.
1981 Tartan 33 #168
Ajax_MD is offline
post #6 of 13 Old 03-13-2014 Thread Starter
I should'v mentioned that the area is small, about 3" wide by 6" long. So at about 55 degrees I would definitely have time to thicken and apply it. When we say it isn't as strong (which is exactly what I've heard before) does anyone have any idea by how much?
If it were say 70% - 80% the strength of normal West system, well that would probably be ok..if it were only 30%-40% as strong, well that probably would not be worth it.
Also, does anyone know if the 5-min epoxy will chemically bond to normal west system? Maybe I could do the first 2 coats with G5, and then finish off with the normal stuff?
post #7 of 13 Old 03-13-2014 Thread Starter
Ok, given that - I think I'll just use G5 for fairing in the surface flaws and use the regular stuff for the glasswork and surface coats.
Thanks all!
post #8 of 13 Old 03-13-2014
West has free technical support if you can call them.
They'll tell you the exact strengths, differences, best choice of materials to use.
dacap06 likes this.
hellosailor is offline
post #9 of 13 Old 03-13-2014
jsaronson's Avatar
Buy a good heat gun. You can cut the cure time a lot.
jsaronson is offline
The Following User Says Thank You to jsaronson For This Useful Post:
Reefpoints (03-13-2014)
post #10 of 13 Old 03-13-2014
Just re-read your orig. post. Those must be some hellacious dings/gouges if you feel you need to put a layer of fiberglass on to strengthen the repair.
How about some pics so we can see what you're working with?
CS 36M DIANTHUS
Bronze and West system epoxy ambianceack Gear & Maintenance 5 05-25-2012 06:40 PM
Help choosing my barrier coat system: Interprotect vs. West System vs. Other? Beersmith Gear & Maintenance 30 02-09-2011 02:10 PM
West Systems six10 epoxy ajf10 Gear & Maintenance 7 04-27-2009 02:51 PM
Curious about the West Epoxy System BigAssHam Sailboat Design and Construction 14 11-22-2007 10:48 PM
Paint and West System Epoxy Marktesno Gear & Maintenance 2 03-31-2001 11:19 AM
