Bulkhead repair question (finishing) - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree6Likes
Old 03-13-2014
priceless9192 is on a distinguished road
As my bulkhead project is in its final stages in my San Juan 28 'Enterprise', i need some advice. I have pulled out every piece of wood on the interior and used as templates for new Jorbet Marine plywood. All pieces are installed with stainless wood/fiberglass screws and bolts. i am now looking at some rough cuts as i walk around the galley. My question is can i fill and fair the gaps which meet the cabin roof with marine grade fiberglass body filler? i plan on taping straight clean lines on the bulkheads and cabin roof before i begin working with the material. Even though the deck is 100% firm, i want to know if i will have any problems with the deck naturally flexing especially while under sail. This seems like a decent option for me, rather than going the painstaking route of cutting 1 3/4 pieces of oak trim to conform the the cabin roof.
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 03-13-2014
SVTatia is on a distinguished road
Re: Bulkhead repair question (finishing)
Is your mast deck or keel stepped?
You need to insert something soft, like closed cell foam to avoid a hard spot. Even though the deck is 100% firm, it still flexes and you don't want a hard spot holding it up and stressing the glass.
christian.hess likes this.
  #3
Old 03-13-2014
christian.hess's Avatar
"Nubile Southern Sailor"
christian.hess is on a distinguished road
this is our tabbing to the deck
foam inside...
Islander 36 now FOR SALE!
  #4
Old 03-13-2014
you can see the foam here
  #5
Old 03-13-2014
finished bulkhead
not the prettiest...still need to paint and trim and install cabinets and the such but its way sturdy and no hard spots so to speak...the foam was just packed in then initial tabbing to keep it in place then laid up after that....
you can see the hull liner in the background...mine was firmly attached to the hull there so I tabbed to liner...I know its not the best solution but since we did major tabbing elseewhere compared to stock tabbing I think Im ok
im hoping it is...
SVTatia likes this.
  #6
Old 03-13-2014
How firm does closed cell foam get? Is it sandable when cured? the rig is deck stepped and has a solid oak compression post which is original and intact
  #7
Old 03-13-2014
Insert the foam and cover it with wood trim or such. A picture would help us to better understand and provide the proper advice.
  #8
Old 03-14-2014
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Use core foam like Airex or Core-Cell, not the closed cell stuff that gets used for upholstery
  #9
Old 03-15-2014
mitiempo's Avatar
mitiempo will become famous soon enough mitiempo will become famous soon enough
Use close cell foam but it doesn't have to be anything expensive. I have used Ethafoam in the past. All it is there for is to space the bulkhead from the hull/deck so there are not any hard spots. When finished the tabbing on both sides of the bulkhead takes all the loading.
You don't have to use foam at all really. Morris Yachts uses a spacer, tabs one side, and then removes the spacer before tabbing the other side.
Brian
  #10
Old 03-15-2014
^^^^x2 a lot of tabbing is done this way...or removed this way like you say
the worker said he preffered doing it this way...I thought foam would keep a better line to fillet and stuff.
originally a lot of boats simply use wood spacers....tab one side...remove then tab other side...the air gap is there and the tabbing does its job
foam is just a simple way of keeping that line if you will and cushion a bit...more than likely over time it will just desintegrate with the heat and all
when real question I have always wondered is about filleting...in essence the fillet is harder than the tabbing so really you kind of are making a hard spot but its thin...the tabbing should flex a bit but be strong....dunno just always wondered...well see what happens on my boat at least jajaja
You may post attachments
You may edit your posts
Bulkhead Repair proposal eko_eko Gear & Maintenance 6 10-01-2013 08:43 PM
New production boat interior finishing and repair prior to comissioning turban10 Boat Review and Purchase Forum 2 09-10-2012 12:17 PM
Bulkhead repair Barquito Gear & Maintenance 6 11-20-2011 10:23 AM
Finishing Sea Hood Repair L124C Gear & Maintenance 10 07-17-2009 01:35 AM
bulkhead repair olepedersen@yahoo.com Irwin 0 04-15-2006 09:12 AM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
