Fabrication: Ranger 29 Rudder Post Flange - SailNet Community
 2Likes
  • 2 Post By gedaggett
post #1 of 8 Old 03-13-2014 Thread Starter
One of the boats in the fleet needed to have a the rudder post flange to be replaced. As you can imagine you can't just run down to the old trusty Walmart and pick up a new one on a boat that is 40 years old and way out of production. So I sourced the material and routed one with some modifications.
The old flange was fastened with only 3 10-24 screws which I was not good as one of the bolts had broken and the other two allowed some serious play. I Programmed it to have 6 holes and a larger footprint to spread out the load on the fiberglass.
I used the CNC router to make the part. I first made 6 templates out of HDPE (High Density Polyethylene) with different size post holes (varying by .064) to get fitment as the old one had worn away some and was allowing some play in the rudder. The material is wickedly expensive. It is fiber reinforced Phenolic and cost $107 per square foot!!! Mistakes would be costly so I made one out of HDPE to test the height settings of the router first. In this picture you can see the original, fit test piece, the test run and the new one half way through the routing process.
The material is held down on the router with vacuum but since the piece was so small (4.25x4.5) I was concerned about it moving on the table and messing up the piece. For that reason I used a process called onion skinning. I leave a very thin skin on the bottom side of the part that keeps it attached to the rest of the material and with the added surface area it doesn't move.
You can see how thin the skin is as the light shows though it.
I then use a table mounted hand router with a round over bit to remove the skin. I put a piece of masking tape on the material so as not to scratch up the surface.
Final result looks pretty good. I am installing it tomorrow and will take some photos of it on the boat and post an update.
Faster and krisscross like this.
gedaggett is offline
post #2 of 8 Old 03-13-2014
no longer reading SailNet
Alex W's Avatar
Re: Fabrication: Ranger 29 Rudder Post Flange
Nice work!
I have a small CNC mill at home and it can be very handy for making one-off repair items on the boat. I have access to a much larger one as well, though I haven't had a project that required a large custom object yet.
Alex W is offline
post #3 of 8 Old 03-14-2014
Nice work!.. Did you consider just using the HDPE itself? rather than the costly material used (realize it's 'the same' as what was there)
Faster is online now
post #4 of 8 Old 03-14-2014
Memopad's Avatar
Very cool! The flange on my Ranger 28 is round and has a million bolts going around it. Don't have a picture handy but it seriously has like 12-16 bolts in a circle around it.
I need to replace that upper flange myself one of these days. Also need to redo the bottom bearing.
1978 Ranger 28 and a fleet of Mini 12's.
Ropes and rigging and splicing, oh my!
Memopad is offline
post #5 of 8 Old 03-14-2014 Thread Starter
HDPE doesn't have the same non compression value as the phenolic. Phenolic is very hard and does not compress. Also HDPE is too soft. I know it is expensive but it was the right material to use in that application. The entire weight of the rudder sits on this flange so had to be Phenolic.
The Following User Says Thank You to gedaggett For This Useful Post:
Faster (03-14-2014)
post #6 of 8 Old 03-14-2014
The complication on the R28's top bushing is that it's round AND tapered.. we made a new one for my brother's R28 years ago but it was tricky.
post #7 of 8 Old 03-14-2014
Memopad's Avatar
That doesn't sound fun, I had no idea it was tapered.
Memopad is offline
post #8 of 8 Old 03-14-2014
Tartan 27' owner
CalebD's Avatar
Very nice work Gary!
Everybody has one:
CalebD is online now
Ranger 33 Rudder rhamlin Gear & Maintenance 3 08-30-2012 01:29 AM
rudder head flange movement... again! Rockter Gear & Maintenance 1 04-20-2012 08:53 AM
Ranger 37' 1973 Compression post cpatters General Discussion (sailing related) 2 05-05-2009 03:11 AM
8.0B rudder post dorourke S2 5 12-09-2008 01:40 PM
rudder post jrwright Gear & Maintenance 2 05-14-2004 09:25 AM
