Ablative paint to cured barrier coat? - SailNet Community
 1Likes
post #1 of 12 Old 03-19-2014 Thread Starter
When I was applying barrier coat to my rudder this past weekend (after many repairs), it never occurred to me that I would want to apply the bottom paint (Micron extra) in the "hot" fashion before full cure.
Well, now I realize that was a mistake. Given that, what is the best method to apply the ablative over the barrier coat?
Details:
Barrier coat: 5 coats of epoxy, the last 3 of which were mixed with West 422 barrier coat additive.
Paint: Micron extra
My best guess of what to do:
1)Clean off amine blush by washing entire surface with warm water and a blue scrubby.
2) Lightly scuff surface with 220 grit sandpaper
3) Wipe down with rubbing alcohol for final dust/grease removal
4) Paint with bottom paint.
How long between coats of bottom paint?
Any tips/tricks/advice to improve my plan?
Thanks all!
Reefpoints is offline
post #2 of 12 Old 03-19-2014
I don't discuss my member
Fstbttms's Avatar
Re: Ablative paint to cured barrier coat?
Ask your questions here:
Antifouling - Yachtpaintforum.com - Page 1
Fstbttms is offline
post #3 of 12 Old 03-19-2014
aeventyr60's Avatar
A good primer is a must on the barrier coat to get the bottom paint to properly adhere. A good scuff with 80 grit on the barrier coat then a primer should do the trick.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is online now
post #4 of 12 Old 03-19-2014
rubbing alcohol isopropal contains a very small amount of oil bittering agent, not a good thing. "IF" you can obtain pure alcohol it is much better.
Zen is a matter of recognizing reality.
desert rat is offline
post #5 of 12 Old 03-19-2014 Thread Starter
Do you know of a good type/brand of primer appropriate for this?
FstBttms, Thank you - I'll ask this question there too.
desert rat, sorry I said rubbing alcohol but in fact I use denatured alcohol bought from the solvent section at Lowe's/Homedepot. Is denatured alc any better or worse than acetone? Acetone dries so fast the rag is often dry before I'm done wiping down the surface..
post #6 of 12 Old 03-19-2014
mitiempo's Avatar
Ask the paint manufacturer. Nobody knows paint better than the company that makes it.
aeventyr60 likes this.
Brian
mitiempo is offline
post #7 of 12 Old 03-19-2014
Ditto that! As I recall, there's a customer service number on the can's label. I have called them and talked directly with a technician who really knew the products.
Sailormon6 is offline
post #8 of 12 Old 03-19-2014
mitiempo's Avatar
It is in their best interest that you get good long term results.
Brian
mitiempo is offline
post #9 of 12 Old 03-19-2014 Thread Starter
Originally Posted by Fstbttms View Post
Wow, that is one rough site. At first it wouldn't let me register since it had identified me as spam! I'm not spam, I promise. (It eventually allowed me after I turned off my proxy and VPN - I guess it wants a resolvable ip address...)
Then it won't let me post a new thread until an administrator activates my account. Sheesh - all for a paint forum!
post #10 of 12 Old 03-19-2014
mitiempo's Avatar
Not every forum lets anybody in like this one.
Brian
mitiempo is offline
Barrier coat or just bottom paint tsell Gear & Maintenance 13 12-13-2013 04:50 AM
Bottom paint over Gel Coat without Barrier Coat? WagTheDog Gear & Maintenance 17 07-15-2012 07:33 AM
bilge paint with Barrier Coat? Skipper Joe Gear & Maintenance 2 09-26-2010 02:28 PM
Barrier Coat & Antifouling paint shipley Gear & Maintenance 7 08-09-2009 09:18 AM
Paint Build-up or Barrier Coat? cas8100 Gear & Maintenance 29 05-09-2008 11:25 AM
