03-24-2006
Thanks all for your input. Here's what another same-boat owner told me - in case anyone is contemplating the same thing I was...
Only certain transmissions take the 30 wt engine oil. Most use “red” transmission fluid not engine oil. The two are not at all compatible. Ours is a 1997 Cone type transmission and it does use engine oil instead of transmission fluid. Yours apparently uses transmission fluid and should be replaced with transmission fluid. Different transmissions are used on the same model engines so you can’t assume someone with the same engine has the same transmission.
Looks like my husband will be crawling around in the engine room on his belly this w/e to take a better look at the tranny...
Susan
LaLeLu 40' Caliber
Merritt Island, FL
