Luff track info - SailNet Community
post #1 of 3 Old 03-23-2014 Thread Starter
Luff track info
I bought a sad old 15' sailboat for cheap recently. One of the most apparent problems with is is the luff track screwed onto a square fiberglass mast. The track is in several segments, and the joints between them are not properly aligned. To add to this, the metal is bent in places. I have to make sure each individual car makes it past the joint. This is very time consuming. I am looking to improve or replace this track.
Can you people who are familiar with sailing hardware tell me what kind of track it is? What is it called? Where can I get spare pieces in case something breaks?
I have attached a picture of a piece of the track in question and one of it's sail cars.
magnocain is offline
post #2 of 3 Old 03-24-2014
paulk's Avatar
Re: Luff track info
You should be able to find it in catalogues under "ltrack". Sailnet may have what you need:http://shop.sailnet.com/advanced_sea...&Submit=Search
Measure what you have and find the same size.
paulk is offline
post #3 of 3 Old 03-24-2014 Thread Starter
Re: Luff track info
Upon a new line of searching, it appears to be a 5/8" Schaefer track.
Tags
car , joint , luff , sail , track
Luff in the luff of main sail eggman2001 Learning to Sail 9 08-16-2012 02:12 PM
The right track for sail track Skipper Joe Gear & Maintenance 4 07-26-2011 11:26 AM
Loose Luff, How Come? montenido Gear & Maintenance 6 07-23-2011 07:17 PM
Luff stlye luff tape dryclean General Discussion (sailing related) 3 06-20-2009 04:17 PM
tuff luff rbtpfe9 Gear & Maintenance 2 06-03-2004 11:43 AM
