Muriatic Acid in holding tank - Page 2 - SailNet Community
 2Likes
post #11 of 16 Old 03-28-2014
Brewgyver's Avatar
Re: Muriatic Acid in holding tank
Originally Posted by Samuelmonosov View Post
(snippage)There are several natural septic system cleaners which use natural enzymes to break down the crud. You can get them cheap at Home Depot.
While the enzymatic products may help with sludge, they will do nothing for the crystallized uratic salt buildup. The problem is well known in the plumbing industry, especially in commercial buildings, and has been around forever, but exasperated by the introduction of ultra-low water consumption fixtures, not to mention water-free urianls. Naturally, the chemical industry started marketing Uratic Salt Removers at least 25 years ago. All of the products marketed for this problem STILL use HCl as the active ingredient.
RichH likes this.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
post #12 of 16 Old 03-28-2014
BINGO ! Thank you
Those of us with hard water and septic systems deal with these issues all the time. Enzyme's don't do squat. I pour acid down my drains to "clean out" the pipes about twice a year. You learn after you replace ALL your plumbing.
benesailor is offline
post #13 of 16 Old 03-28-2014
islander bahama 24
newhaul's Avatar
Back in the old days when I ran sewage systems for the US navy we used citric acid to remove the scale in the urinal piping on the ships worked good and is and was non caustic to rubber and the various metals in the system also it is not harmful to people or the environment heck you could eat it if you really want to but I would not recommend that.
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #14 of 16 Old 03-29-2014
just ducky
I personally don't feel vinegar does anything unless you started using when the system was new and you used it very regularly. It is just too weak.
An acid is an acid, but I feel it is better to use ones more designed just for home scale removal use like CLR
Using acid is just for the hoses etc. it isn't going to clean the holding tank. The amount you would have to add to maintain a pH lower enough to remove scale in a holding tank that has sludge in it would be a lot.
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
post #15 of 16 Old 03-29-2014
pdqaltair's Avatar
I've done a fair amount of testing of de-scaling chemicals, both for industrial and sailing head applications, and the most widely available chemical that I liked was CLR.
Hydrochloric acid. Effective. Murder on most metals, and not good for stainless. Requires care, Will destroy nitrile (cracks) and nylon (melts--not just ropes but fittings too). I wouldn't use it unless I was 100% certain there were no nitrile or nitrile parts in the system... and both are common in certain brands.
Lime-a-way. Sulfamic acid. Bad on nitrile (heads other than Jabsco, hoses) and acetal (strainers).
CLR. Lactic acid. Probably the best chemical compatibility and pretty aggressive as well. There is risk to Hytrel and ABS, but I've not seen those in heads.
Vinegar. Weak acetic acid. From what I've seen, this is mostly in your head. Certainly it won't attack established layers. Probably works for folks that flush enough water and use it very regularly... and even then CLR would be more effective and economical, if the does were equivalent. But folks do like their home remedies. They'd be better off using the vinegar and veggy oil on salads.
Always a compromise.
RichH likes this.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
pdqaltair is offline
post #16 of 16 Old 03-29-2014
We use a product from tract ecological called Sew Clean check it out Welcome to Trac-Online
May you weather all storms
dorymate1 is offline
Convert existing steel freshwater tank to blackwater holding tank? patrickstickler General Discussion (sailing related) 7 09-24-2010 07:55 PM
Muriatic Acid: A cautionary tale about cleaning mixing elbows, etc. oft Gear & Maintenance 1 07-28-2008 06:55 AM
battery acid problem, acid resistant epoxie jasonr575 Gear & Maintenance 18 02-28-2007 09:35 PM
Re: Where to buy- Anhydrous Lanolin and Muriatic Acid NewsReader Mass Bay Sailors 0 02-26-2007 03:15 PM
Where to buy- Anhydrous Lanolin and Muriatic Acid NewsReader Mass Bay Sailors 0 02-26-2007 12:15 PM
