safe cooking - Page 21 - SailNet Community
 96Likes
post #201 of 301 Old 04-01-2014 Thread Starter
captain jack's Avatar
Re: safe cooking
Originally Posted by Puddin'_Tain View Post
Look at the current draw. Even a small micro way will require more current than a small boat can easily provide. Almost all compact microwaves call for a 15A circuit. Even if you can get away with 10A, that's 10A at 120V, or 1200W. In other words, the draw on your boat's batteries would be about 100A at 12.5V. On big boats, with big battery banks and gensets, that's doable. On a 27-foot boat, not likely.
oh. i wasn't asking because i was considering it; just out of curiosity. i wouldn't have any place to put it.
The only rules that really matter are these: what a man can do and what a man can't do.---Captain Jack Sparrow
1971 Cal 27
captain jack is offline
post #202 of 301 Old 04-01-2014 Thread Starter
Re: safe cooking
You mean non-pressurized alcohol, right?
yes. quite right. i thought i'd typed 'non' in there. my mistake.
1971 Cal 27
post #203 of 301 Old 04-01-2014 Thread Starter
Re: safe cooking
Originally Posted by GeorgeB View Post
I think BoatUS is combining propane or at least they address it in their article. More telling is they attribute the decrease in stove fires to a decrease in alcohol stoves.
“6) Stove - 1%
Stove fires appear to be less common (1%) than in the past, probably due to fewer alcohol stoves being installed on new boats. Still, alcohol can be a dangerous fuel; though it can’t explode, an alcohol flame is hard to see. One fire was started when a member tried to light the stove and gave up because he couldn’t see the flame. Unfortunately, he had succeeded, but didn’t realize it until he got a call from the fire department. Only one fire was started by propane; a portable stove fell off a counter and ignited a cushion.”
True story. Anyone of you familiar with the Sierra Nevada Mountains and Priest Grade? Priest is an original road (trail?) that went up to Groveland in the gold country. Very, very steep grade that lasts for five miles or more. Big signs on both ends prohibiting large trucks, vehicles with trailers and RVs. It is about 15-20 miles shorter than the “modern” road and cuts travel time considerably. On this particular day an RV driver decided to take the shortcut down and as forewarned, burnt out his brakes about halfway. Fortunately, he was able to use the hillside as a brake to stop his runaway vehicle instead of going over the cliff edge and certain death. The family evacuated safely but the burnt out brakes caught the surrounding grasses on fire which caught the RV on fire. Roaring fire, with the roof burnt off, the vehicle walls acted as a chimney. Gas from the fuel tank added to the conflagration. With fire all around, the propane tank started to cook off. When it did, The poppet valve released and a hundred foot flame shot out through the roof with a whoosh. The biggest explosion were the tires cooking off and expanding then bursting. Those went off with a bang that I would have thought what would happen to the propane tank. Not to say propane can’t explode, but this was one exciting afternoon in any case.
Can I make one last plea for bringing back coal for cooking? It’s not volatile, won’t explode, compact, and has about twice the BTUs as wood or charcoal.
i'm probably going to sound silly for asking but are you serious of joking about the coal? my grandparents used to heat the house with a coal stove and had a kero stove to cook on.
1971 Cal 27
post #204 of 301 Old 04-01-2014
Re: safe cooking
Originally Posted by SVAuspicious View Post
If you are so concerned with the explosive potential of propane as to rule it out you can make inductive cooking work but your battery bank better be big (off hand, 1200 Ah or so) and you should have the charging capacity to match unless you eat out a lot.
Let's not forget how explosive batteries can be.....
Boredop is offline
post #205 of 301 Old 04-01-2014
Re: safe cooking
Coal? No good for boats, too hard to get good coal in most of the developed world, and too easy to have a monoxide problem.
But speaking of spaghetti, that's a classic "ain't gonna happen" on a 6800btu burner. Can't boil a big pot of water on that. Although, most of us were taught how to cook pasta the rich way, with a big pot of rolling boiling water. If you just bring the water to a boil, and then shut the burner and come back to stir the pasta every few minutes, it cooks up just fine. May take 20 minutes instead of 10, but it cooks just fine without the need for copious amounts of boiling water. Great way to save fuel, whatever kind it is.
hellosailor is offline
post #206 of 301 Old 04-01-2014
Re: safe cooking
My god Captain Jack,
Get a propane stove; thousands upon thousands of boats come with them, Statiscally you probably have a better chance of burning your boat down with any other fuel. Install it properly and you souldn't have any issues.
That or hang a charcoal grill of the back of the boat.
benesailor is offline
The Following User Says Thank You to benesailor For This Useful Post:
Boredop (04-01-2014)
post #207 of 301 Old 04-01-2014
Re: safe cooking
Originally Posted by MastUndSchotbruch View Post
Interesting.
However, this is about fires, not explosions. I suppose the statistics includes galley fires caused by liquid (and solid) fuels. But if there is a propane leak, the result is not a fire but BOOOOM
I really doubt that would make much different in the overall results. The point stands, if you one is worried about fire, one should rip out all their electrical systems and revert to LED headlamps, charts and a sextant, long before worrying about propane (assuming its installed correctly).
Jeanneau 54DS
Minnewaska is offline
post #208 of 301 Old 04-01-2014
Re: safe cooking
I remember when Ebeneezer Scrooge used.............
post #209 of 301 Old 04-01-2014
Minnesail's Avatar
Re: safe cooking
So what I've gathered is that, done right, propane and alcohol are both very safe. The danger of a fire or explosion from either of them is a small fraction of the other dangers involved in boating.
But for a person with a small boat who is trying to keep systems simple and costs down it sure sounds like alcohol comes out a winner. Two or three hundred bucks for an Origo and you're done. No solenoids, no hoses, no valves...
At least that's how I'm leaning for cooking in my tiny boat.
olson34 and captain jack like this.
Catalina 22
on a starboard tack
Minnesail is offline
The Following User Says Thank You to Minnesail For This Useful Post:
captain jack (04-01-2014)
post #210 of 301 Old 04-01-2014
69' Coronado 25
socal c25's Avatar
Dock
Re: safe cooking
If your worried about fires then DON'T cook ANYTHING with GREASE or OIL, those cause more fires than the fuel you use. I would worry more about a dragging anchor than a cooking fuel fire.
SVAuspicious likes this.
"There are those that stand at the shore looking to the sea, wondering, and there are those standing at the helm looking back at shore, knowing." - Kurt Leisenfelder
"Fiberglass shells that let us breathe, let us smell, keep us from going numb"- Kurt Leisenfelder
My Avatar is a pic of my son - Jan 19, 2014.
socal c25 is offline
Solar cooking... travlin-easy General Discussion (sailing related) 4 01-30-2013 03:52 PM
Solar cooking bwalker42 Provisioning 24 10-04-2012 12:51 PM
Cooking in a gale..... MedSailor Gear & Maintenance 8 02-27-2012 12:11 PM
Looking for a Cooking Author socaleditor Provisioning 1 02-06-2005 03:52 PM
cooking duffyM Provisioning 10 09-04-2003 04:28 PM
