safe cooking - Page 7 - SailNet Community
 96Likes
post #61 of 301 Old 03-30-2014
Re: safe cooking
Originally Posted by captain jack View Post
wouldn't a kero cook stove stink like a kero heater? and what about the fumes? kero heaters can kill you. kero is safer to handle than, say, gas.
Kerosene stinks if it is not properly vaporized. For instance, if you put it in an oil lamp (with a wick), that will happen. Or if your stove/oven is not properly maintained or operated.
If properly vaporized, good quality kerosene has no smell.
Fumes: yet, if you spill it, it will smell. But it will not explode and it will burn only with difficulty (you can throw a match in a puddle of kerosene and it will not burn). It will also smell if not properly vaporized (typically not enough pre-heating).
Kero heaters can kill you if you operate them without enough fresh air (carbon monoxide poisoning). This applies to ANY open flame heater (kero, gas, wood, coal, ...).
So, in summary, the worst consequence of poor maintenance or poor operation of a kerosene stove is that it smells. For LPG, it is instant death of the operator and anyone else on board.
Which one do you choose?
olson34, captain jack and harmonic like this.
MastUndSchotbruch is online now
post #62 of 301 Old 03-30-2014
Re: safe cooking
Originally Posted by Puddin'_Tain View Post
It's a boat --- things break, wear through, jiggle loose, etc.
Thats what we call a complete and total lack of routine maintenance.
barefootnavigator is offline
post #63 of 301 Old 03-30-2014
Re: safe cooking
Originally Posted by barefootnavigator View Post
If you have rats on your boat propane is the least of your problems. I guess a plane could crash into your boat that may sever the line.
I would not consider a gas explosion a minor problem.
The boat in the slip next to me (on the Chesapeake Bay) some time ago discovered a mouse on the boat. It happens.
post #64 of 301 Old 03-30-2014
Re: safe cooking
Did his boat explode?
post #65 of 301 Old 03-30-2014
Don't call me a "senior"!
Puddin'_Tain's Avatar
Re: safe cooking
I'm sorry. I didn't realize I was talking to a perfect boat owner. For us mere mortals, sh*t happens.
"If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps a bit better than most." --- E.B. White
Puddin'_Tain is offline
post #66 of 301 Old 03-30-2014
Re: safe cooking
Now that you know let me give you a little free advice that will save your life. Maintain your boat and it will maintain your life and lifestyle. How easy is that???
post #67 of 301 Old 03-30-2014
Re: safe cooking
A used origo stove from Sweden, because a new 2 burner is $250-350. Denatured alcohol stove fuel-$10 to $20 a gallon at hardware stores, quart at walmart. Hard not to spill when filling canisters. You need to see pics of canister.
sidney777 is offline
post #68 of 301 Old 03-30-2014
Re: safe cooking
(It was more her boat than his, actually. Anyway.)
No, it did not explode.
And your point is? I don't even know what stove they had on the boat (they have since moved). Let us assume it was indeed gas.
Then you have clearly shown that there is ONE boat with an LPG system that did NOT immediately blow up. Even though it was certainly possible, just as the boat that exploded this week because of the rat bite.
I would feel so much better now if I had a gas system.
post #69 of 301 Old 03-30-2014
Re: safe cooking
Here's a story of a boat owner who wouldn't have had any real problems IF her boat's stove had been a non-pressureized alcohol unit. Granted, she made a pretty dumb mistake by using a lighter after she smelled gas, but mere mortals make mistakes from time to time.
post #70 of 301 Old 03-30-2014
Re: safe cooking
I would feel so much better know if I had a gas system.
Let me take a minute and explain how a properly used and maintained propane system works very simply. There is a shut off at the tank it should be shut off IE NO FUEL IN LINE OR BOAT. RTFM
Solar cooking... travlin-easy General Discussion (sailing related) 4 01-30-2013 03:52 PM
Solar cooking bwalker42 Provisioning 24 10-04-2012 12:51 PM
Cooking in a gale..... MedSailor Gear & Maintenance 8 02-27-2012 12:11 PM
Looking for a Cooking Author socaleditor Provisioning 1 02-06-2005 03:52 PM
cooking duffyM Provisioning 10 09-04-2003 04:28 PM
