safe cooking - Page 9 - SailNet Community
 96Likes
post #81 of 301 Old 03-30-2014 Thread Starter
captain jack's Avatar
Re: safe cooking
Originally Posted by MastUndSchotbruch View Post
Kerosene stinks if it is not properly vaporized. For instance, if you put it in an oil lamp (with a wick), that will happen. Or if your stove/oven is not properly maintained or operated.
If properly vaporized, good quality kerosene has no smell.
Fumes: yet, if you spill it, it will smell. But it will not explode and it will burn only with difficulty (you can throw a match in a puddle of kerosene and it will not burn). It will also smell if not properly vaporized (typically not enough pre-heating).
Kero heaters can kill you if you operate them without enough fresh air (carbon monoxide poisoning). This applies to ANY open flame heater (kero, gas, wood, coal, ...).
So, in summary, the worst consequence of poor maintenance or poor operation of a kerosene stove is that it smells. For LPG, it is instant death of the operator and anyone else on board.
Which one do you choose?
solid point, there. i am used to wick type space heaters....so, smell came to mind.
The only rules that really matter are these: what a man can do and what a man can't do.---Captain Jack Sparrow
1971 Cal 27
captain jack is offline
post #82 of 301 Old 03-30-2014 Thread Starter
Re: safe cooking
I would not consider a gas explosion a minor problem.
The boat in the slip next to me (on the Chesapeake Bay) some time ago discovered a mouse on the boat. It happens.
check that out. you are pretty close by.
1971 Cal 27
post #83 of 301 Old 03-30-2014 Thread Starter
Re: safe cooking
Originally Posted by sidney777 View Post
A used origo stove from Sweden, because a new 2 burner is $250-350. Denatured alcohol stove fuel-$10 to $20 a gallon at hardware stores, quart at walmart. Hard not to spill when filling canisters. You need to see pics of canister.
really? it goes for $10 to $20 a gallon? how long does a gallon last?
1971 Cal 27
post #84 of 301 Old 03-30-2014
Re: safe cooking
one gallon goes 12 hours give or take.
barefootnavigator is offline
The Following User Says Thank You to barefootnavigator For This Useful Post:
captain jack (03-30-2014)
post #85 of 301 Old 03-30-2014
Re: safe cooking
That powerboat did not catch fire because of the propane stove. I guarantee you that.
It caught fire because of the inexperienced operator, who failed to properly inspect and maintain their equipment, which just happened to include a stove.
If the same guy lit up a cigarette at a gas station and set it on fire, would you blame the gasoline? Ahuh, I thought so.
IIRC BoatUS has a web article someplace that reported the greatest number of "stove" fires came from those nice safe alcohol stoves, that use a fuel which is pretty famous for leaking and burning with an invisible flame, which then spreads like any other wildfire.
Go to Costco, buy the big boxes of Snickers Bars. No need for cooking or flames onboard any boat at any time, any way.
barefootnavigator likes this.
hellosailor is offline
post #86 of 301 Old 03-30-2014 Thread Starter
Re: safe cooking
Originally Posted by capta View Post
Gee, do you have a stove in your car, I don't! Never have! No, the point there was that DRIVING is more dangerous than having a propane stove on a boat; do you understand that point now?
For crying out loud, talk about missing the point, much!
you don't have a stove in your car? how on earth do you fix lunch when on road trips?
bljones likes this.
1971 Cal 27
post #87 of 301 Old 03-30-2014
christian.hess's Avatar
Re: safe cooking
that what the engine is for to heat up a burrito
Lou452 and captain jack like this.
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #88 of 301 Old 03-30-2014
Re: safe cooking
"Kerosene stinks if it is not properly vaporized. "
MastUndSchotbruch-
Everyone has a different reason for why their own kerosene doesn't stink. But the bottom line is that some of us can smell the kerostink no matter what quality kerosense (paraffin oil) you are using. No matter how you trim your wicks. No matter how you tune your engines. (Diesel.)
The stuff always burns with an odor, some people simply are unable to detect it.
There are in fact genetic components that explain why some people simply cannot smell, or test, various compounds. Kerostink hasn't been researched, but I'd bet it is just another one of them.
Last time I won a nice bet, everyone said "Oh, those two beers taste exactly a like." Sure, just like Coke and Pepsi.
post #89 of 301 Old 03-30-2014
Don't call me a "senior"!
Puddin'_Tain's Avatar
Re: safe cooking
If you buy a gallon can, denatured alcohol is generally about $13 or $14 per gallon. However, a five-gallon can (a bit harder to find, but usually available at paint supply and some non-big-box hardware stores) runs $25 to $35, or $5 to $7 per gallon.
BTW, even at the high end of the $/gal range, compared to all the other costs involved when owning a boat, stove fuel is pretty trivial; less than the price of a mediocre bottle of wine per month.
"If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps a bit better than most." --- E.B. White
Puddin'_Tain is offline
The Following User Says Thank You to Puddin'_Tain For This Useful Post:
post #90 of 301 Old 03-30-2014
Re: safe cooking
The Origo manual states 6 to 7 hrs per full canister. It takes one quart to fill each canister. My experience is in line with what the manual states. If you don't use your stove much you will find that some alcohol evaporates in time.
christian.hess likes this.
mitchbrown is offline
The Following User Says Thank You to mitchbrown For This Useful Post:
Solar cooking... travlin-easy General Discussion (sailing related) 4 01-30-2013 04:52 PM
Solar cooking bwalker42 Provisioning 24 10-04-2012 01:51 PM
Cooking in a gale..... MedSailor Gear & Maintenance 8 02-27-2012 01:11 PM
Looking for a Cooking Author socaleditor Provisioning 1 02-06-2005 04:52 PM
cooking duffyM Provisioning 10 09-04-2003 05:28 PM
