Cetol Marine Finish Woes - Page 3 - SailNet Community
 13Likes
post #21 of 35 Old 03-31-2014
DearPrudence's Avatar
Re: Cetol Marine Finish Woes
Having just completed my exterior teak re-finishing project this winter, I will say that when I saw bubbles, I would use a 3M Scotch Brite pad between coats of Cetol. It slowed me down some, but, the results were (are) worth it.
DearPrudence is offline
post #22 of 35 Old 03-31-2014
rbyham's Avatar
I too think wood prep is key. It is very easy to stop just short of the final sanding surface needed. Any "soft" teak layer will create a less than perfect application of any varnish. My guage for having reached the right level of sanding is when a tack cloth run over the surface does not catch at all... My recommendation would be to work with a short section and take it to complete smooth 400 grit. If that works you have your answer...
rbyham is offline
The Following User Says Thank You to rbyham For This Useful Post:
tomhuntdmd (05-26-2014)
post #23 of 35 Old 04-01-2014
I have been using the Cetol Marine for 4 years now. Holds up much better than Spar Varnish, although not much chance for sun damage here in the Pacific NW.
In Hawaii my 5 coats of Spar Varnish used to last 6 months.
I have found the Cetol Marine a durable finish that holds up well and is scratch resistant. My last 4 coats lasted over 3 years. The only thing I don't love is the color. Seems they add some sort of iron compound to decrease sun damage to the finish, and it works!
If you are going to use it, don't shake it, or any varnish product. Only stir it and get all the thick stuff up from the bottom of the can. Shaking will cause bubbles. Also, I cannot believe all the people using sponge brushes. OK, so you are in Tahiti and can't find a Lowes, that is a good excuse. Otherwise, buy a good china bristle brush and go slowly for a really nice finish.
I don't like the Cetol Gloss finish. Way too shiny and way to slippery!
Teak forever.
Newport 30 Mark III 1986
Uncle Joey says, if the screw won't go all the way in, you are not using a big enough hammer!
heelangle is offline
post #24 of 35 Old 04-01-2014
CapnChuck's Avatar
Our boat spends most of its life in south Florida and the Bahamas. We have found, over the years, that the base coat last a very short time without the gloss. It might not be a problem in northern climates. We try and spend as little time as needed in northern climates. Chuck
Our Blogs
CapnChuck is offline
post #25 of 35 Old 04-01-2014
Right on! Cetol now recommends 2 or 3 coats of Cetol (light, natural or regular) followed by 2 coats of gloss.
Seaduction is offline
post #26 of 35 Old 05-25-2014
It's been a year, but I'd like to add my voice to the mix - I have used cetol for almost 5 years and find that the Jenn foam brushes work best - they're available on E-bay. I have not had a problem with air bubbles in the finish, using a light touch, not over-working it on the wood, and keeping a wet edge. Also, I'd add that I use about 2 coats of cetol marine, and then follow up with one coat of cetol gloss, which seems to help maintain the finish longer. I let each coat dry, sand lightly or use a green 3m scrub pad, and then apply next coat. B.
NewBaySailor is offline
post #27 of 35 Old 05-25-2014
Try wiping the wood with acetone before applying the cetol. It will remove moisture from the wood. Also let the cetol breathe a few moments in the shade after stirring. I use cetol with a foam brush and put it on as thin as possible. A few thin coats are better than 1 thick coat. Good luck
bljones likes this.
lennyv is offline
post #28 of 35 Old 05-26-2014
JimsCAL's Avatar
Redid all the outside teak on my Cal 33 this spring. Took off the varnish with Citristrip, then heat gun on the tough spots, then sanding. Used Cetol Natural Teak and had no problems. I followed the recommendation on the can for the "two rag" cleaning using paint thinner. I like the look of the Natural Teak. Matches to color of varnished teak very well.
JimsCAL is offline
post #29 of 35 Old 01-25-2016
Gentlemen, Please forgive me for bringing up this old thread but it was so helpful. I've been Cetol'ing the outside teak. Not much to it, companionway boards, a few hand rails, some trim. Didn't start with much knowledge but I've got a poop load now. Most of this stuff I brought home and am doing in the house where the light is good and you can SEE EVERY DUST PARTICLE! For days I thought they were bubbles but it was dust as so clearly stated by Seaduction, in this thread. When I read that I went in and looked closely and sure 'nuff, thats what it was. I've been sanding and swearing and doubled up on my dose of Prozac, couldn't figure it out. Now I turned the ceiling fan off and got me a tack rag and move real slowly and I've got three nice coats of clear on with no DUST! Looks almost perfect. Of course, as usual, by the time I figure it out, I'm almost done. Oh, well....I appreciate all I read here by you geniuses. Here some links to pics....kevin
FloridaBoy is online now
post #30 of 35 Old 01-26-2016
FB, looks good from here!! Congrats.
As I said above, I'm not a big fan of Cetol. I truly hope your experience is better. Does it require a primary thinned coat to penetrate the wood?
Jeanneau 54DS
Minnewaska is offline
Cetol...off! cgha33 Gear & Maintenance 18 12-29-2010 03:19 PM
Sikkens-Cetol Marine Natural Teak? BigMoe Gear & Maintenance 12 05-05-2009 09:40 AM
new cetol fishboyneil Gear & Maintenance 44 07-05-2008 09:15 PM
Cetol jccrane Gear & Maintenance 5 03-31-2004 03:43 PM
Cetol vs cetol light Lastmango69 Gear & Maintenance 2 07-22-2003 04:12 PM
