Swaged Ball end stop fittings? - Page 2 - SailNet Community
 1Likes
post #11 of 13 Old 05-18-2014
mitiempo's Avatar
Re: Swaged Ball end stop fittings?
Originally Posted by blackflagsailor View Post
I am sailing a 14' dinghy. Not a big cruiser. Not sure if the setup is different on larger boats. I have a length of steel rope with a captive pin shackle that attaches to the sail head. At the opposite end there is an eye. I use a length of yacht rope shackled to the eye of the steel wire rope for a downhaul to hoist the sail.
If there is a shackle at the head of the sail and an eye at the other where does the ball fitting go?
Brian
mitiempo is online now
post #12 of 13 Old 05-18-2014 Thread Starter
blackflagsailor's Avatar
I'll make a little presentation here with pictures!
Okay, so I have a I have a length of steel rope with a captive pin shackle that attaches to the sail head. The sail attaches by feeding into an internal slotted track at the back of the mast.
The steel rope section of halyard passes over the top of the mast through a pair of sheaves.
So many inches from the captive pin shackle, there is a stop fitting swaged to the steel line. I can't remember the measurement, but it is a pretty exact science. This fitting slips into a special bracket on the front of the mast, near the top and locks the halyard in place, keeping the sail up.
At the opposite end of the steel line there is an eye. I use a length of yacht rope shackled to the eye of the steel wire rope for a downhaul to hoist the sail.
blackflagsailor is offline
post #13 of 13 Old 05-27-2014
blackflagsailor asked a good question:
How would I use a stop for the halyard with rope instead of steel wire?
There's a reason for the ball stop in a halyard. How does one add one, that works with a halyard lock, when replacing the wire halyard with amsteel?
jpeurich is offline
Is this swaged fitting failing? Reefpoints Gear & Maintenance 18 03-27-2016 06:39 PM
Stop, the end, an exit plan for sailing. Lou452 General Discussion (sailing related) 24 03-06-2014 07:40 AM
Swaged fittings vs. mechanical fittings yachtthor Pacific Seacraft 24 04-21-2012 04:48 PM
Fico 1-1/4" end stop needed sandycohen Gear & Maintenance 0 05-10-2011 01:03 PM
Removing a swaged fitting (stop) lfein Gear & Maintenance 2 06-10-2007 07:27 PM
