J24 Cabin Sole - Veneer stained-What to do? - SailNet Community
post #1 of 5 Old 04-02-2014 Thread Starter
rhr1956's Avatar
My friend brought over his cabin sole and some assorted pieces of teak for me to refinish. The old varnish on the sole was literally falling off. I removed 90% with a broad knife. The rest required sanding. The wood was damp where the varnish was peeling away. I let it dry and hit it with the sander. The holly strips where the wood was damp is darkened (mildew?) and the darker teak is splotchy. I don't want to sand too deep. Is there anything I can use to even it out before applying new varnish?
rhr1956 is offline
post #2 of 5 Old 04-02-2014
One of None
deniseO30's Avatar
Re: J24 Cabin Sole - Veneer stained-What to do?
try Bleach
My last project!
deniseO30 is offline
post #3 of 5 Old 04-02-2014
jsaronson's Avatar
Wood bleach, not Clorox! Use much less water than the directions state, let it sit and dry, wash, reapply
jsaronson is offline
post #4 of 5 Old 04-02-2014
One of None
deniseO30's Avatar
it should have oxalic acid in it. most teak cleaners have it.
My last project!
post #5 of 5 Old 04-03-2014 Thread Starter
rhr1956's Avatar
UPDATE...We scrubbed the cabin sole with BarKeepers Friend and water...and a white Scotchbrite pad. Rinsed very well with clear water from the garden hose. Toweled dry and then followed up with a couple of rounds using white vinegar and a sponge. After a couple of hours the treatment had made a real improvement. Not perfect but plenty good.
rhr1956 is offline
What do you have on your cabin sole? cthoops General Discussion (sailing related) 89 03-29-2015 10:38 AM
Putting in new floors and a cabin sole. Also planning a new cabin layout. Advice? sully75 Gear & Maintenance 4 10-02-2013 01:30 PM
Cabin sole Dmarina Gear & Maintenance 7 04-27-2011 10:12 PM
Cabin sole Dcneuro Gear & Maintenance 16 09-27-2008 07:34 AM
Cabin sole nelsonsmoody Gear & Maintenance 9 11-07-2006 10:40 AM
