Old 05-13-2001
rtcooke is on a distinguished road
Martec Geared Folding Prop
I have just replaced my original martec folding prop with the Martec geared prop. I am wondering if it may have been installed incorrectly, reverse is almost non-existent and can''t even be used to slow the boat down.
Has anyone had this problem? Can it be corrected or should I just put the reconditioned one back on.
Old 05-13-2001
Jeff_H's Avatar
Super Moderator
If the pitch and diameter is correct and the prop is opening all of the way the geared propos should work as well as your older ''flopper'' type. The geared props are better than the ''floppers'' because you are more likely to have both blades close. The ''floppers'' really needed the hinge pin vertical to guarentee that one blade would not flop open. That said, the geared props have more friction closing and so it is a good idea to take the boat up to a reasonable speed, and then kill the engine in gear. That is more likely to force the blades shut.
As to your reversing problem, it may also be a matter of blades not opening all of the way. If I have any doubt that the blades have opened all of the way (I have a Gori geared folding prop) I give a quick burst of reverse and then power up in reverse slowly so as not to ''spin'' the prop.
Good luck
how to remove folding prop? mcagney Gear & Maintenance 1 07-20-2005 10:23 AM
FOLDING PROP RE-FIT drynoc Gear & Maintenance 1 12-30-2003 04:16 AM
Remove folding prop dsiegfried Gear & Maintenance 0 03-16-2003 04:51 PM
used folding prop chris1514 Racing 0 03-13-2003 05:47 AM
Folding Prop for Volvo MD5A mikehoyt Gear & Maintenance 0 12-02-2002 04:25 AM
