Handheld GPS recommendations - Page 2 - SailNet Community
 11Likes
post #11 of 29 Old 04-05-2014
christian.hess's Avatar
Re: Handheld GPS recommendations
Originally Posted by PaulinVictoria View Post
Garmin 76CSx
x2 I have this one...oops I have the 76cx....my bad
now about charts how expensive and good are they for simple plotting? I have only used this gps for basic navigating on land...but are the charts really accurate?
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #12 of 29 Old 04-05-2014
MikeOReilly's Avatar
Originally Posted by christian.hess View Post
...now about charts how expensive and good are they for simple plotting? I have only used this gps for basic navigating on land...but are the charts really accurate?
Hi Christian, I bought charts for all the Great Lakes, out the St Lawrence River. I think it cost me ~$150. This was three years ago. I wonder if they're now cheaper due to pressure from online sources. I bought the same set of charts for my iPad (iNavX with Navionics charts) for ~$50.
I find our Garmin charts to be generally pretty accurate. We do most of our route planning using larger paper charts, or now sometime the iPad. The small screen on the 76 are too small to do route planning very well. But I use it constantly for under way plotting and navigation.
Why go fast, when you can go slow.
MikeOReilly is offline
post #13 of 29 Old 04-05-2014
I have the 78SC and like it just fine. It gets used as a backup, although it was the primary device for a while.
Also take a look at the Garmin Oregon 650.
MarkSF is offline
post #14 of 29 Old 04-05-2014
Everything that is "waterproof", other than golf balls, depends on seals. And seals all age and leak and fail, the only question is WHEN.
So by all means get the best IP67 milspec waterproof golf ball you can, but spend the extra $25 to put it in a good quality waterproof vinyl pouch with a lanyard, that is easily replaced when it starts to look unreliable.
hellosailor is offline
post #15 of 29 Old 04-05-2014
TQA
Bombay Explorer 44
TQA's Avatar
I like the Garmin 72 76 interface and screen display.
However I have 5 units and only one works reliably.
TQA is offline
post #16 of 29 Old 04-06-2014
Irwin 25
andrewalexander's Avatar
might want to take a look at the Garmin GPSMAP 62S - it has some features that you may like for kayaking
http://www.amazon.com/Garmin-GPSMAP-62S-Handheld-Navigator/dp/B003IHV6YG
andrewalexander is offline
post #17 of 29 Old 04-07-2014 Thread Starter
Thanks to all for your good advises! This makes my choice pretty easy...
seafrontiersman is offline
post #18 of 29 Old 04-07-2014
Cruiser2B's Avatar
I use the Garmin 72, its a simple unit...no charts. I used OpenCPN(free) when getting/planning waypoints for trip with up to date NOAA charts loaded into laptop. I then load way points into Garmin 72 and then just navigate to waypoints. Pretty cheap and so far reliable setup.
I have a $20 GPS puck plugged into laptop safely below decks which gives me a poor mans chartplotter using OpenCPN....its functional and gives me a visual position on chart but surely not waterproof but does give me some redundancy.
I have both setup on boat for less than $180 not including laptop.
christian.hess likes this.
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
post #19 of 29 Old 04-07-2014
hey I just installed Opencpn but it says I have no charts installed...
how do I go about installing some charts for pacific coast of central america?
thanks
post #20 of 29 Old 04-07-2014
Cruiser2B's Avatar
thanks
I downloaded my charts from NOAA website as a file. I used help function in program to get instructions...took a few tries to get right format.
I think cruisersforum.com has a section for setting it up.
Sent from my XT907 using Tapatalk
VHF Handheld Recommendations dougshipl Gear & Maintenance 9 12-31-2009 04:00 PM
Handheld GPS captainVT Gear & Maintenance 23 12-04-2009 11:55 PM
Handheld GPS recommendations? wildlawnc Gear & Maintenance 14 10-18-2007 09:22 PM
Handheld GPS recommendations mikecaptnkidd Gear & Maintenance 5 02-20-2004 05:36 PM
Recommendations for handheld VHF? PBzeer Gear & Maintenance 6 12-19-2002 12:52 PM
