How much paint will I need to do the bottom of a 30 footer - SailNet Community
 5Likes
post #1 of 26 Old 04-05-2014 Thread Starter
I am painting my tartan 30 for the first time. I will be using vc17 and I swear someone told me that they use 2quarts but the chart for the product says I will need a gallon and a half. I dont want to buy any more than I need. I guess it could not hurt to buy a little at a time and just paint till I'm done? Or is a dry edge a problem. Either way if you have a similar size boat and have done this before, please let me know how much paint you use.
abrahamx is offline
post #2 of 26 Old 04-05-2014
Re: How much paint will I need to do the bottom of a 30 footer
Never been able to figure that one out myself. My 36 Columbia should take a gallon or more, but I get decent coverage with 2 quarts. Your supposed to put on 2 coats which would almost be the amount they recommend, but I never do. In the fall at haul out there is just a little slime and a zebra mussel here and there.
capt jgwinks is offline
post #3 of 26 Old 04-06-2014
Sailor
Gladrags1's Avatar
It matters where you boat. In the warmer Chesapeake, you would need more paint than in cooler waters. So you have a fellow Michiganer there who also states 2 quarts is sufficient. I hope you are using an ablative as paint piles up and then flakes off in chunks, causing a total redo of the bottom. So I would get 1 gallon and use what you need. Quarts are more expensive than gallons.
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #4 of 26 Old 04-06-2014
scratchee's Avatar
My 27-foot boat takes a little more than a gallon, so I get a gallon and a quart. If you can buy it locally, I'd get a gallon and then see how much more you need after the gallon is gone.
Be aware that two quarts costs almost as much as a gallon.
EDIT: Maybe VC17 only comes in quarts anyway?
scratchee is offline
post #5 of 26 Old 04-06-2014
TQA
Bombay Explorer 44
TQA's Avatar
VC 17 is thin and goes on thin so you need MUCH less than conventional ablative..
I used it on my 22ft trailer sailor
TQA is offline
post #6 of 26 Old 04-06-2014
My 45 footer takes 2 gallons for the first coat. 2nd coat goes on thinner than the first.
jann is offline
post #7 of 26 Old 04-06-2014
snake charmer, cat herder
zeehag's Avatar
1-2 gallons is what i have always used on 30-35 ft boat with 2 coats on bottom and 2-4 on waterline and leading edges.
christian.hess likes this.
formosa 41, cruising tropics
zeehag is offline
post #8 of 26 Old 04-06-2014
Page 37 of the Interlux guide has an estimation table.
http://www.yachtpaint.com/Literature...14-usa-eng.pdf
Our Beneteau First 36.7 takes 7 of the 3/4 quart cans to just cover.
TejasSailer is offline
post #9 of 26 Old 04-06-2014
MarkofSeaLife's Avatar
Dock
All boats take one more tin than you can afford, a quarter gallon more than is sold in the gallon can.
My boat takes 2 1/4 gallons f'ing waste lol
jimgo likes this.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #10 of 26 Old 04-06-2014
SchockT's Avatar
I use 1 gallon for 2 coats of Petit Horizons on my 30'er. I only have to paint every 2 years. I also put it on thicker in areas that I scrub such as the waterline and the rudder. 1 coat definitely isn't enough; I am sure if I only applied 1 coat I would have to haul every year, which is much more expensive than a half gallon of paint!
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
Don Casey: Paint Waterline Stripe with Bottom Paint asdf38 Gear & Maintenance 23 03-05-2016 06:50 PM
Bottom Paint RobGallagher Gear & Maintenance 1 03-26-2013 03:48 PM
Paint thinner for soft ablative bottom paint jameswilson29 Gear & Maintenance 7 11-26-2012 12:56 PM
Bottom paint prep, chipped paint josrulz Gear & Maintenance 16 02-14-2010 08:24 PM
which bottom paint? DropTop Gear & Maintenance 9 06-24-2009 09:58 PM
