Old 05-13-2001
shipley is on a distinguished road
Yanmar 2QM15 Problem
I have a 20 year old Yanmar 15hp in my 34 Irwin and recently had problems starting it after not using it for 3 months. I used starter fluid to get it going but it is now puting out grey smoke and black carbon looking particles in the exhaust water. It will only start with the throttle in full open position then quits after 45 seconds. Any thoughts? Also, does anyone know the proper fuel bleeding procedure on this engine.
Old 05-14-2001
Jeff_H's Avatar
Super Moderator
First guess on any diesel is dirty fuel, water in the fuel or a clogged filter. That said starter fluid is tough on an engine and you have damaged a ring or a valve.
Old 05-17-2001
Thx - I''ll check fuel - hope its the first one and not second. Any way telling if it is the valves or rings for sure?
Old 05-18-2001
hoggard is on a distinguished road
I have a Yanmar 2GM (13 hp)
Had same black particles issue with loss of power. corrected with new fuel, new fuel filters removing sludge and H20.
Old 05-18-2001
PSSEATTLE is on a distinguished road
I have a 3QM30. A friend has a 1Q and another a 2Q.
Check for water in fuel. The high pressure fuel pump is quite sensitive to water. It is quite expensive to have overhauled or replaced. A bad load of fuel can do this. Change your filters.
Secondly, I have primed these by barely loosening the hex at the top of each injector adjacent the fuel line while the engine idles. Fuel will come out along with air. Do one at a time. Collect loose fuel with a rag.
Third, if you haven''t already done this, check for water in the crankcase by viewing the oil on the dip stick. If it is milky, you have more serious problems such as a blown head gasket or cracked block.
Additionally, check your air filter to be sure it is clear.
Also be sure the supply (low pressure pump) is providing fuel to the high pressure pump by opening a fitting or hose on its outlet and checking for flow.
Old 05-18-2001
A cold engine will emit carbon.The grey smoke is the ether (starting fluid) combustion products. Best to figure why you need starting fluid. Bad fuel, dirty or worn injectors or pump, or worn rings and valves are all culprits. I would approach it with attention in the respective order.
Best of Luck
Catalina 34 Starting Battery Problem Garytami Gear & Maintenance 6 03-06-2010 11:33 PM
Prop for Morgan OI w/ Yanmar 3GM30F cwarwick Gear & Maintenance 1 11-16-2004 01:17 PM
Funny Electrical problem Bruceo1 Gear & Maintenance 2 12-15-2003 06:01 AM
1981 Honda 9.9, 4 stroke o/b, Idle problem randj65 Gear & Maintenance 4 06-19-2002 10:59 AM
Engine Oil Pressure Problem msamelso Gear & Maintenance 2 02-20-2001 06:25 PM
