Awlgrip cleaner/wax - SailNet Community
 1Likes
post #1 of 19 Old 04-06-2014 Thread Starter
Awlgrip cleaner/wax
Anyone have a suggestion for an appropriate one step cleaner/wax for an Awlgrip painted topside? Preferably something that could be applied with an random orbital on slow speed. (actually it's Alexseal, but fewer have heard of it and it should react the same)
It would definitely not want an abrasive cleaner and doesn't need one. Just to clean off bilge outlet stains.
I know some say no wax, but I disagree. I think it protects the finish. Easily washed off with the right detergent to prevent yellow build up.
Jeanneau 54DS
Minnewaska is offline
post #2 of 19 Old 04-06-2014 Thread Starter
Re: Awlgrip cleaner/wax
Anyone used this?
On-line Product Catalog:*3M? Marine Clean & Shine Wax, 09033, Clear, 16.9 oz, 6 per case
Jeanneau 54DS
post #3 of 19 Old 04-06-2014
Care and Maintenance Instructions for AlexsealŽ
Premium Topcoat 501
3.
Sealing and Protecting
It is recommended to apply a high quality wax or polymer sealer designed for surfaces
painted with polyurethane at least 2-3 times per year. This will act as a sacrificial coating
that will protect the paint and can dramatically improve the coatings life expectancy.
4.
Important Notes
Many companies manufacture products for sealing and protecting painted surfaces. Only
use products that are specifically designed for surfaces painted with
polyurethane. These products should not contain abrasives or caustic chemicals.
Do not let moisture/water collect or be trapped between a Polyurethane Topcoat and
plastic film, shrink wrap, hardware, seat cushions, or wet fabric. Polyurethane topcoats
should not be continuously submerged under water. Moisture/water held against a
Polyurethane Topcoat even for a few days can result in bubbles forming in the
Polyurethane Topcoat.
5.
Removing Stains
Remove stains from a polyurethane finish as soon as possible. Some stains
can actually etch the surface of the paint and embed into the coating. If a stain cannot be removed with
a mild detergent during the washing process, solvents may be used to loosen the stain.
Always start with mild solvents such as Mineral Spirits, VM & P Naphtha or Denatured
Alcohol. Harsher solvents such as Acetone and Lacquer Thinner should only be used as a
last resort. After removing the stain with solvent, wash the area with a mild detergent and
clean water to remove all solvent residues.
NU-Finish car wax
benesailor is offline
post #4 of 19 Old 04-06-2014
CapnChuck's Avatar
Wax will ruin the Awlgrip finish. There is no shortcuts. Use Awlwash or car wash soap that is safe for all paints. Use only AwlCare on the finish. That is unless you don't mind having the boat need another coat of paint in the near future. Chuck
SchockT likes this.
Our Blogs
CapnChuck is offline
post #5 of 19 Old 04-06-2014
If you use Nu-finish; by hand only. Pointless to use a buffer.
post #6 of 19 Old 04-06-2014
Send a message via Yahoo to dacap06
Minnie,
Awlgrip is not like regular paint. It stratifies as it cures. The resin tends to rise to the suface of the paint as it dries, giving the paint a thin skin, while the pigment part sinks down. This skin is what is shiny. It protects the pigmentation, which is why the paint lasts 10 years if well cared for.
I'm not sure about Alexseal. I expect you should visit the web site and see what the vendor says.
The long and short of Awlgrip is that it should never be machine buffed, and should never be buffed at all if it still looks good, cause it is way too easy to screw it up. That skin is very thin and you can go through it. The Awlgrip web site says clean it with Awlwash and protect it using Awlcare.
There's a ton of help and advice available here on Sailnet with regard awlgrip and you should read it, but the best bet is trust what the manufacturer and knowledgeable distributors say. Use the link above to see what the manufacturer says; use this link to see an insteresting compare/contrast by Jamestown distributors. To query google for information from a specific site like Sailnet, pattern your query like the following search for Awlgrip buffing (but without the quotes):
"site:sailnet.com Awlgrip buffing"
Hope this helps!
Regards,
Tom
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #7 of 19 Old 04-06-2014
post #8 of 19 Old 04-07-2014
Don't use wax, it does indeed make a right mess. Awl wash and Awlcare are the way to go. Awlcare is a protective sealant and seems to last quite well. Although the instructions tell you not to, I applied the Awlcare with a random orbit buffer but on very low speed. Heat is the enemy of Awlgrip.
Neither product is particularly expensive so why use anything else?
MarkSF is offline
post #9 of 19 Old 04-07-2014 Thread Starter
Thanks for the links. Alexseal is actually the next gen of Awlgrip. Same inventor that waited for his non-compete to expire. He even makes it in the original factory, as I recall. It is an LP paint, just like Awlgrip, but is buffable and repairable. I'm very familiar with the stratified structure of Awlgrip, but thanks anyway.
Alexseal actually recommends wax, although, I hadn't seen it in the links above. If I were to use a buffer, I specifically mentioned a random orbital on slow speed. Its the heat of a circular buffer that melts off the top layer. I've seen a real pro get away with it, but I would not try. I'm not opposed to doing this by hand. I was just being lazy after a long day of commissioning.
Awlcare is easy enough to apply, but lasts about a week or two and does zero cleaning. It never really has that waxed look either. It's just a sealer.
Jeanneau 54DS
post #10 of 19 Old 04-07-2014 Thread Starter
I had a brilliant idea. I just sent a note to Alexseal.
I like this product for the plane and it would be perfect for the topsides, if acceptable. It really cleans well and lasts a couple of months. Best of all, it can haze over in the direct sun and bake as long as you like, before wiping off. I hope its acceptable, now that I think of it.
https://www.arrowmagnolia.com/produc...ZE-56p1217.htm
Jeanneau 54DS
new awlgrip for my old Alden, awlgrip color combinations that work questions? sharedwatch General Discussion (sailing related) 25 03-07-2013 09:19 PM
wax off cutterorient Gear & Maintenance 3 05-03-2009 11:02 AM
Wax..What's Best?? 7Psych Gear & Maintenance 28 10-29-2007 02:35 PM
Spar cleaner & wax TrueBlue Gear & Maintenance 0 02-15-2005 07:25 AM
