Fuel tank fabricator in Annapolis area? - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Old 04-09-2014
josrulz's Avatar
Unpaid Intern
josrulz is on a distinguished road
Hi all,
We pulled our diesel fuel tank on our '84 Sabre 34 because we had some ongoing filter fouling issues last season. On our boat, you can't inspect the tank in place, but you can remove it so we did.
The yard folks think that it MIGHT be pitted in the bottom, but they are not sure. I looked at it myself (I'm no expert), and I see little black specs that don't seem to move when you scratch at them with a long screwdriver. The yard guys think that might be pits with carbon built up in them. But they aren't sure.
Our tank was not OEM (which was Mirax). It was a replacement that was made in 2002 by Luther's in Rhode Island of 1/8" aluminum (an upgrade from original). I'm checking with Luther's to find out if they can make a replacement from plans still on file (based on serial number).
In the meantime, I'm trying to figure out whether we really NEED a new tank or not. And to that end, I may also need a local fabricator if Luther's doesn't still have the plans. I may need help to A) figure out if the tank needs replacement, B) repair the current or fabricate a new tank for us.
Does anyone know of a fabricator in the Annapolis are who works on fuel tanks and might be able to help?
Thanks in advance for your help.
-J
1984 Sabre 34 Mk I
  #2
Old 04-09-2014
T37Chef's Avatar
T37Chef will become famous soon enough
Re: Fuel tank fabricator in Annapolis area?
no experience with your issue but I wonder if it has to be a fuel tank fabricator vs just a metal fabricator? You may try calling Clean Fuels in Annapolis Clean Fuels Associates, Inc. | Tank Cleaning, Filtration, Polishing or see this thread Fuel Cleaning Service - Yes or No?
Shawn
Tartan 37 - S/V Windgeist
Photo by Joe McCary
  #3
Old 04-09-2014
But if not...
paperbird is on a distinguished road
Highly recommend Jeff Carter of Carter Fabrication in Millersville. Used him for several fab projects and he did great work on all.
  #4
Old 04-09-2014
jsaronson's Avatar
jsaronson is on a distinguished road
Why metal?
Moeller Marine Online - Home - Home Page
  #5
Old 04-09-2014
Maine Sail's Avatar
2002 & 1/8" thick.. Holes? Very doubtful.. If Bud made it this is a QUALITY aluminum tank made with quality aluminum. The standard Mirax tank was half that thick and they too can still make you one, and up the wall thickness if you request it.
I highly doubt you have pin holes in a 2002 tank. Possible welding slag/splatter. Take a long awl or sharpened coat hanger and see if you can "prod" these like a cavity. I suspect they are likely proud of the tank not etched into it...
BTW I have a 34 year old Sabre / Mirax tank in my barn, in an "experiment", that has virtually no corrosion and it is 34+ years old.... Owner wanted it cleaned but once we got it out he decided that for the $400 clams, to just order a brand new one with 1/8" walls.
Does An Empty Tank Accumulate Water?
______
-Maine Sail / CS-36T
  #6
Old 04-09-2014
billyruffn's Avatar
billyruffn will become famous soon enough
Not in MD, but if it gets to buying a new tank you might try getting a quote for a new tank from Boyd Welding in FL. They built a new day tank for my boat and shipped it to RI. Price was good and product excellent. You could probably ship them the old tank and they could take it from there.
Boyd Welding LLC ? Custom Aluminum Diesel Fuel and Gas Tanks
  #7
Old 04-09-2014
Boatsmith's Avatar
BoatSmith
Boatsmith is on a distinguished road
Speedytank.com in Jersey
BoatSmith ---Boatbuilder
  #8
Old 04-09-2014
josrulz's Avatar
Unpaid Intern
Thanks for the feedback, everyone. Here's an actual picture of the inside of the tank. Probably doesn't tell you much, but here it is nonetheless.
-J
1984 Sabre 34 Mk I
  #9
Old 04-09-2014
josrulz's Avatar
Unpaid Intern
Maine Sail, I can confirm there are no leaks or pinholes at this time. The only question has been about whether or not there is pitting which could lead to pinholes sooner rather than later. I'm not convinced that I'm looking at pitting here, one way or the other.
Thanks again for your thoughts on this.
-J
1984 Sabre 34 Mk I
  #10
Old 04-09-2014
SteveInMD is on a distinguished road
Atlantic Spars & Rigging in Eastport did a nice job on a tank for me.
You may post attachments
You may edit your posts
Chainplate Fabricator in Annapolis Area jasn Chesapeake Bay 1 03-07-2014 05:45 PM
Teak Fabricator in the Annapolis area aa3jy Chesapeake Bay 5 12-08-2013 05:51 PM
Tank Fabricator near Annapolis SteveInMD Gear & Maintenance 1 03-31-2009 07:59 AM
looking for S2 7.3 in Annapolis area NomadPa S2 1 09-18-2006 11:59 AM
DC/Annapolis area phowson Crew Wanted/Available 2 05-18-2006 11:40 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
