Tri-Matrix ports, glass or acrylic? - SailNet Community
 1Likes
  • 1 Post By JustinC25
post #1 of 3 Old 04-11-2014 Thread Starter
I am planning to replace the original, non-opening portlights on my Montgomery 23 with Newfoundmetals Tri-Matrix portlights. I decided that all stainless is too heavy and unnecessary for this boat. I like the Tri-Matrix over other plastic ports because it can be adjusted both on the dog and hinge side, so it should be easier to keep it leak free.
My question is, is there a major advantage in tempered glass as opposed to acrylic. The thickness is 8mm (5/16 inch) for each. I am looking at the 7x15 inch size opening. My guess is that the acrylic is strong enough and lighter, while glass is more resistant to scratches and perhaps lasts longer. The difference in cost is only $30 per port.
Which one would you choose and why?
meteuz is offline
post #2 of 3 Old 04-11-2014
JustinC25's Avatar
Send a message via AIM to JustinC25
Re: Tri-Matrix ports, glass or acrylic?
I installed the Tri-Matrix ports on my boat and had the same question. After discussing it with NFM, if I recall, if you take the glass lens option, they give you the glass lens and you swap out the acrylic yourself. I could be wrong, it was a couple years ago, but I think that's the case. I do remember thinking, well I'll just start with the acrylic and then if they fade, then spend the money on glass since it was going to only be a $30 upgrade per lens in the future. BTW, I would recommend the stainless steel screen upgrade. They are some excellent ports, a huge improvement over other plastic ports, and the self sealing (no sealant used) is a huge plus. Good luck with the project.
meteuz likes this.
Justin
Chesapeake Bay
JustinC25 is offline
post #3 of 3 Old 04-12-2014
The thing to consider is what happens if the material fractures. The tempered glass will disappear in a shower of crystals. The acrylic will require a piece of duct tape to reseal. Unless the tempered is laminated, which 5/16" suggests. That's a serious game-changer. Then, the fractured "light" will remain more of less stuck to the PVB interlayer and the intact light will support it. If it's laminated, go with that.
DonScribner is offline
Tags
glass , newfoundmetals , portlights , tri-matrix
SH Ggxx 2150 AIS Matrix+ trantor12020 Gear & Maintenance 12 01-11-2014 11:48 AM
Standard Horizon Matrix AIS+ GX2150 RobGallagher Electronics 38 03-27-2013 03:23 PM
New Found Metals: TRI-Matrix Ports Beersmith Gear & Maintenance 11 01-20-2012 11:18 AM
Standard Horizon Matrix AIS VHF radio! downeast450 General Discussion (sailing related) 16 05-05-2010 02:43 PM
Lexan VS Acrylic weephee General Discussion (sailing related) 18 04-12-2010 10:11 PM
