Resealing veneer seam? - SailNet Community
 3Likes
post #1 of 12 Old 04-11-2014 Thread Starter
The back of my cabin is covered with strips of veneer with varnish over them. Over the years water has gotten into the seams and the veneer has expanded the varnish is peeling away. Anyone have any good ideas to restore this? My latest idea is to sand it down and use an epoxy coat to harden the damaged edges of the veneer and re-varnish over it. Does this make sense? I've never used an epoxy coat under varnish.
Vedrfolnir is offline
post #2 of 12 Old 04-11-2014
christian.hess's Avatar
Re: Resealing veneer seam?
dremel and bevel out the seam...clean dry, insert nice cherry or mahogany trim bedded in epoxy...sand and varnish over
clean out, dry, caulk like a deck
or..clean out fill with thickened epoxy and varnish over
thats what I have done in the past with the exception of adding the wood trim...but have seen it done nicely
peace
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
The Following User Says Thank You to christian.hess For This Useful Post:
Vedrfolnir (04-11-2014)
post #3 of 12 Old 04-11-2014
Looking at the pictures it's tough to tell...but are you sure it's veneer? I might think about removing the wood and replacing with new, especially if you want to remove the old instruments. If it is veneer, then piecing in a new piece of wood or sanding the damaged veneer out and filling with epoxy might be a fairly good fix.
1983 Lippincott 30 s/v Red Horizon
Regent Point Marina Topping, VA
RedHorizon is offline
post #4 of 12 Old 04-11-2014
I was going to say looks like nice cabin top wood...not veneer...
post #5 of 12 Old 04-12-2014
Sailor
Gladrags1's Avatar
I'm thinking that it looks like plywood and the top layer is peeling away at the edges. I think you want to explore options to repair this carefully to restore it properly and maintain the looks of a wood doghouse. I'd ask professional woodworkers to see what they would do. Search woodworking forums and ask them.
Tod
Mandolin, Bayfield 36 out of Rock Creek, Chesapeake Bay.
Sent from my iPhone using Tapatalk
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is online now
post #6 of 12 Old 04-14-2014
Once known as Hartley18
Classic30's Avatar
Dock
Doesn't look like veneer to me either... but your plan sounds about right:
  1. Remove instruments and fittings.
  2. Remove ALL the old varnish with a heat gun and scraper (or chemical stripper if you don't feel comfortable with using a heat gun).
  3. Light sand with 80 grit and then a coat of CPES to seal the bare timber.
  4. Re-coat with fresh varnish.
It's a weekend job and not hard to do. Have fun.
Classic30 is offline
post #7 of 12 Old 04-14-2014
Omatako's Avatar
If you're going to use 80 grit paper, be sure to only sand along the grain or use a random orbital machine. Even a moderate angle will leave scratches that will be there forever. I would use something lighter than 80 grit.
I must say, that doesn't look like veneer and I don't think many boat builders would use veneer on an external bulkhead such as this. I reckon it's solid planking.
Arthur C. Clarke
Omatako is offline
post #8 of 12 Old 04-14-2014
TomMaine's Avatar
Originally Posted by RedHorizon View Post
Looking at the pictures it's tough to tell...but are you sure it's veneer? .
It looks like a typical wooden cabin construction. Sometimes full width planks were found(old growth forest days), but as often, the back were built up of two or several planks. They were usually joined with a tongue in groove joint. As wood contracts and expands, compression sets in at the joint, and you get an open seam. Once varnish fails(that's your seal against moisture), the joint quickly deteriorates.
Usually(and it may be the case here), a new spline is added to fill the crack. If it's irregular, it may be routed oversized a bit. You may have to do that for a tight joint or you maybe able to just pull the old spline out. Clean the pocket, and fit new.
It's an easy process if you have some experience. Make the spline a bit fat, and sand or hand plane a slight bevel-epoxy-tap in. Once dry, carefully plane it near flush-sand.
I've had to do that in several areas of my wooden cabin. Over 10 years ago, I 'wooded' the back(your's needs that done). If you look closely, you can see the one joint just above the bridgedeck. I had to add a 1/4"x1/4" spline which is epoxied in.
Then if you build the varnish back up(8-10 coats), add maintenance coat once a year(in New England), you're cabin back will be good for 10 to 15 years.
jimgo and christian.hess like this.
Tom Young sailing a 1961 38' Alden Challenger, CHRISTMAS out of
Rockport, Maine.
'I'd have written a shorter post, but I didn't have the time', Mark Twain.
TomMaine is offline
post #9 of 12 Old 04-14-2014
op think of a teak and holly sole...you can emulate that on your cabin side wood
like tom maine says make a thick spline that you can press into...dont woryy if its oversize or to tall...you will shave it down and sand it smooth...
then just varnish over...
I like to seal the wood if bare first...you can also stain it...
then if you can and WANT to some 8 or so coats of varnish
jajaja thats the hard part really
post #10 of 12 Old 04-14-2014
TomMaine's Avatar
Oh no, my friend. This is the BEST part, if you enjoy brightwork.
You're right though on coats, 8 minimum. I'm now 12 years(egads, I'm wearing a watch!), on this cabin back varnish with a single coat each spring.
It looks like it will be several years before I have to do it all again.
That is,...if I can wait that long.
christian.hess likes this.
Rockport, Maine.
TomMaine is offline
Tags
epoxy , restoration , varnish , veneer
Resealing the Stern Tube? Trinidoc Gear & Maintenance 12 08-24-2012 02:04 PM
Ripped Sail along Seam Question CraigCS27 General Discussion (sailing related) 3 08-30-2011 09:07 AM
Resealing Windows ccriders Gear & Maintenance 2 12-05-2010 10:12 AM
Keel pocket seam recommendations needed. fparry SailNet FAQ 3 02-26-2010 01:23 PM
RIB Repair on the seam dsbentley Gear & Maintenance 1 03-15-2007 09:34 PM
