Nylon or aluminum cleats on mast? - Page 2 - SailNet Community
 1Likes
post #11 of 16 Old 04-12-2014
Barquito
Barquito's Avatar
Re: Nylon or aluminum cleats on mast?
Guess I'll have to go on line. Boy are these hummers pricey!
Look on e-bay. Get a few and polish them.
For those that have cam cleats and line clutches, what exactly do you do with the long tail of line? I was about to replace a horn cleat on my mast, hadn't even thought of that problem.
(sorry for the slight thread drift)
Valiant 32
Barquito is offline
post #12 of 16 Old 04-12-2014
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Originally Posted by BubbleheadMd View Post
Seadog is kind of "bottom of the line" gear. Fine for small skiffs and such that don't see any really ugly loads.
Your boat is 31 feet. Instead of cleats, you might investigate line clutches.
Somebody tell me about these.
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #13 of 16 Old 04-12-2014
I use halyard hangers like ( Ronstan Utility Hanger (2 Pack) ). They work much better than trying to jam a halyard onto a horn. And while they have bolt holes, I just epoxy them places, all over the cockpit, near winches, ect. For a couple of bucks they make storing coiled lines easy.
Mad Machine,
Those is a cheap clutch that failed quite embarisingly. Since the load is in line, to have the plate open like that indicates a pretty weird failure method.
Greg
Stumble is offline
post #14 of 16 Old 04-14-2014
Greg,
not so much the failure.. but the mechanism itself. My ancient Sea Sprite as a tiny little bronze cleat on the mast that can be a bit of a pain to get a line secured to and even harder to unsecure
Art Haberland
post #15 of 16 Old 04-14-2014
no longer reading SailNet
Alex W's Avatar
That is a Lewmar clutch, they are usually highly regarded. I am curious about how that one failed. I use and like them because they release well under load.
Dave_E: Fisheries Supply in Seattle has a huge range of cleats to choose from. They have pretty much every product mentioned in this thread in stock.
Greg: I use those same Ronstan hooks in the cockpit of my boat for managing lines. I hadn't considered hanging two on the mast for jib and spin halyards, but it's a pretty good idea. A halyard bag mounted at the base of the mast would also do the trick.
Alex W is offline
post #16 of 16 Old 04-15-2014
Barquito
Barquito's Avatar
Here is an idea for handling the heavier loads of a halyard without popping for a rope clutch. It also provides a way to store the tail. They mounted two cam cleats in line (I understand this is common on racing boats).
christian.hess likes this.
Valiant 32
Barquito is offline
Nylon/Glass fibre or aluminum Mast steps? SanDiegoChip Gear & Maintenance 12 09-05-2016 04:40 PM
Mast cleats, how many preservedkillick Gear & Maintenance 1 05-28-2012 08:49 AM
Cleaning Aluminum Cleats (or is that Aluminium?) josrulz Gear & Maintenance 5 03-11-2010 07:48 PM
Aluminum vs. Stainless cleats bwindrope Gear & Maintenance 11 04-29-2009 05:10 PM
Aluminum cleats- repaint black or leave shiny? Northeaster Gear & Maintenance 6 04-20-2008 01:41 AM
