Whats on the hole where your outhaul comes out? - SailNet Community
post #1 of 5 Old 04-12-2014 Thread Starter
On my boom I am replacing the outhaul line. the boat is new to me and I noticed that the reason why the line was highly chaffed is because the hole it is comming out is just a raw drilled hole with no grommet or anything around it. What can I use here? I am refering to the end that you pull on.
abrahamx is offline
post #2 of 5 Old 04-12-2014
Re: Whats on the hole where your outhaul comes out?
You want something like an exit plate:
Kenyon Exit plates
Full page: http://www.rigrite.com/Spars/SparParts/Exit_plates.html
tempest is offline
post #3 of 5 Old 04-12-2014
You need what's called a thru deck block right at the opening see Harken part number 088.
Take a look at Harken for examples of systems.
Greg
Stumble is offline
post #4 of 5 Old 05-01-2014 Thread Starter
So I want one of these thru deck blocks on both ends of my boom? I do have one on the aft end where it pulls the sail. I am refering to the other end where I pull the line. Thru deck block or exit plate???????????
abrahamx is offline
post #5 of 5 Old 05-01-2014
Exit plates are for when the direction of pull is parallel to the direction it runs (say a main halyard). They cannot redirect the direction of the line like the harken block does.
Greg
Stumble is offline
CS36 Outhaul Nias Gear & Maintenance 7 10-05-2013 01:11 AM
Need Bristol 27 outhaul ChadwickGore Gear & Maintenance 1 07-16-2012 11:54 AM
How to make a 1/2 through hole a 1 1/2 through hole? SanDiegoChip Gear & Maintenance 44 04-26-2010 07:09 PM
How does this outhaul work? Finallybuyingaboat General Discussion (sailing related) 4 07-29-2009 10:25 AM
Outhaul advice agaliha Beneteau 3 12-10-2006 09:55 AM
